Loosing clutch pressure
Old Dec 11, 2003 | 08:12 PM
95excoupe's Avatar
Default Loosing clutch pressure
On long trips where I leave it in 5th for a while or if the car has been sitting for a long time the clutch gets really soft and theres lots of play before it actually catches...I changed the clutch master recently cause it was leaking and it got better but its still doing it...Any ideas on what else it could be maybee the slave is bad???? Thanks
Old Dec 11, 2003 | 08:35 PM
Jer's Avatar
Jer
Default Re: Loosing clutch pressure (95excoupe)
are you still losing fluid? im guessing its due to a bad slave cylinder
Old Dec 12, 2003 | 12:48 PM
95excoupe's Avatar
Default Re: Loosing clutch pressure (GERM)
Not loosing fluid it just gets all soft feeling after a while and if you pump it, the pressure comes back and it feels good again...I guess ill change out the slave and see what that does.....thanks
Old Dec 12, 2003 | 01:16 PM
civic_tuned's Avatar
maybe u need to adjust the clutch or maybe even worse u need a new clutch.
how many miles?
do u haul *** all the time?
Old Dec 12, 2003 | 01:18 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Loosing clutch pressure (civic_type_r)
Its not going to be a bad clutch, its probably the slave or air in the system.
the171
Sep 14, 2017 04:36 PM
rattlecannedEF
Transmission & Drivetrain
Jun 22, 2010 01:28 AM
WTFINEEDBBQ
Nov 22, 2009 02:59 AM
fridayfred3p
Apr 27, 2006 03:11 PM
PreIudeSI
Aug 19, 2003 03:58 AM
