holes on aftermarket fuel rails not drilled all the way?
How come the fpr hole is not drilled out all the way on aftermarket fuel rails? I was stumped for a couple of hours till I figured it out.
Because you might want to use an external FPR. If you look on the end of your aftermarket fuel rail you'll probably see a bigger hole - external FPR.
