wheel gap mystery
the rear wheel gaps on my 90 crx dx are different. check it:
ive got 3 fingers on driver side, whole hand on the passenger side.
driverside:
passenger side:
just got this crx....dont know much about suspension...this is my 3rd crx and this is the first time ive seen this.....anyone got any ideas?
thanks
ps. i dont really like the wheels so dont pick....
driverside:
passenger side:
thanks
I'm sure a fresh set of springs/shocks will remedy the problem.
Nice clean fenders by the way
Not a speck of rust. I'd love to find a clean CRX, but that is pretty much impossible in Ohio.
Just want to chime in and say that I also have uneven wheel gap in the rear. My 1990 Civic Si has less gap on the driver's side than the passenger side. I did the "finger" test and it's almost identical to your's: three on the driver's side, 5 (my whole hand) on the other. The difference is even noticeable if you look at the car from behind when it's on level ground.
I figured the gap on mine was because the car is still 100% stock and the shocks/springs have never been changed. Also, I know that the wife of the guy I bought the car from also drove the car, and well since she's a little "plump" in the rear....well maybe that explains it.
i have a 95 prelude srv and my gap on the driver side is smaller than the passenger side as well... i think the weight bias is due to jdm right hand drive (weight of the driver would even things out a little)... well, maybe get someone to sit in your passenger seat and check the gaps again?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p1driftfiend »</TD></TR><TR><TD CLASS="quote">Just want to chime in and say that I also have uneven wheel gap in the rear. My 1990 Civic Si has less gap on the driver's side than the passenger side. I did the "finger" test and it's almost identical to your's: three on the driver's side, 5 (my whole hand) on the other. The difference is even noticeable if you look at the car from behind when it's on level ground.
Yah I also had this problem before I swapped over to my H&R springs. I guess its from the years and years of always having weight on the driver's side. I mean for all of the car's life, it always has a driver but not always a passenger. So there you go...change the springs and see if that helps.
</TD></TR></TABLE>Yah I also had this problem before I swapped over to my H&R springs. I guess its from the years and years of always having weight on the driver's side. I mean for all of the car's life, it always has a driver but not always a passenger. So there you go...change the springs and see if that helps.
This is a common problem on CRX's there have been people that have the un-even gap even AFTER they change out their shocks and springs. Might have something to do with your bushings as well?? I will soon find out if I have the problem also once I replace my springs/shocks and bushings.
I noticed my problem after installing my H&R springs with tokico blues.
All 4 corners sit differently. I cant quite figure it out. The only thing I think it could be would be the bushings. Guess I need to replace them all and find out
FRKWOO
Dec 1, 2008 10:50 PM
Hoosier Daddy
45
Sep 24, 2003 03:36 PM
