t3/t4b max hp??
Old Dec 10, 2003 | 08:38 PM
Mr.DC2TurBo's Avatar
Default t3/t4b max hp??
I have a LS with a rev hard stage 2 (1.5yrs old) t3/t4b turbo. At the time of purchase I did not know that a t3/t4b and e made a huge difference until it was too late. So now I do not quite remember the trims and a/r of my turbo. I have become boost happy and I am now building my bottom end with JE pistons, eagle rods H beam, hondata s200, and other stuff to up the boost. my question is how efficient is this turbo and at what psi will I see close to 280-300hp? Also, if anyone knows the spec of the LS stage 2 for rev hard (turbonetics turbo) please let me know.
I'm hoping for around 280-300 at 15-18psi with this setup:
rev hard t3/t4b
440cc
hondata s200
skunk2 intake manifold
2.75" exhaust
JE Pistons 9: 5:1
crower rods
STR block guard
stock sleeve
If 280-320 hp is not possible at 15-18psi, what psi is possible to make this pw and what else am I missing to make sure this won't blow??
Modified by Mr.DC2TurBo at 9:56 PM 12/11/2003
Old Dec 10, 2003 | 09:21 PM
Default Re: t3/t4b max hp?? (Mr.DC2TurBo)
anyone??
Old Dec 10, 2003 | 09:55 PM
rocket256's Avatar
all depends some 300hp-400hp
Old Dec 10, 2003 | 10:28 PM
Default Re: t3/t4b max hp?? (rocket256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">all depends some 300hp-400hp</TD></TR></TABLE>
t3/t4b max is 300? I would think atleast 350-400
Old Dec 11, 2003 | 12:03 AM
Seraph0's Avatar
T04B can make a lot of power. 60-1 is a T04B based and it can make a ton of HP. You probably have an H or a V T04B. Those both can make well past 3-400whp. I like pushing compressor wheels to their max.
Old Dec 11, 2003 | 12:08 AM
Boostfed's Avatar
New User
Well I had a DRAG 3 kit for a B16A and it was SUPPOSED to come with a T3/T04B Super V trim compressor wheel and Stage III turbine wheel, well nope we measured it it was actually an S trim wheel and Stage I turbine wheel, it did make 370whp with 21psi and maxed the hell out. And as MarkC said the 60-1 is within the T04B family of compressor wheels which everyone seems to not know or forget, it is bigger than any T04E compressor wheel available and 62-1 also.
Old Dec 11, 2003 | 06:07 PM
Seraph0's Avatar
Default Re: t3/t4b max hp?? (Boostfed)
Yup. My friend had the DRAG3 kit on his 99 Si (he bought the turbo kit in Feb 2000) and it was a Stage1 wheel, but his did have a Super-V.
Old Dec 11, 2003 | 06:54 PM
Default Re: t3/t4b max hp?? (MarkC)
how much hp you guys think at 18 psi? 320hp, possible???
Old Dec 15, 2003 | 11:57 AM
are 440cc injectors big enough for 310hp?
Old Dec 15, 2003 | 12:08 PM
IloveNewt's Avatar
i made 375 whp on a t3/t4b .63 ar stage 3 wheel, V Trim Compressor Wheel maxed out on 20psi on a h23.
Old Dec 15, 2003 | 11:40 PM
Default Re: t3/t4b max hp?? (MordecaiPSI)
how big are your injectors?? I'm afraid 440cc will not be enough now.
Old Dec 16, 2003 | 12:49 AM
MiraiZ's Avatar
440cc isn't gonna cut it...get 550's at least
sean-sports
Mar 3, 2007 03:36 PM
projectPSI
Nov 18, 2005 10:23 PM
Marlon88
Jul 9, 2005 06:05 PM
91DroppedHatch
Nov 10, 2004 09:00 AM
Fuzion
Nov 25, 2003 07:03 PM
