another suspension q
im trying to take the top bolt off the shock
(the one where you takeit off and the spring goes boing)
so im trying to take the nut off with an impact gun, the nut is spinning but so is the shock on the inside of the spring.
is there anyway to get around this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattharper »</TD></TR><TR><TD CLASS="quote">as close to the nut as i can?
with vise grips on the inside of the spring?
sorry im a little unclear on the last post</TD></TR></TABLE>
yup. Whats happening is the entire shaft is spinning preventing you from undoing the nut.
yah....if your really careful you can wrap something around the shock slider and pinch it tight with the vise-grips.....this will stop the shock from spinning so you can hopefuly get that ******* nut off!!.....good luck
You should of break loose all the top bolt while the whole shock was still bolted on the car, I use a hex key to stop it from turn and a allen ranch to loosen it up!!
Then take the whole shock out, compressed it, and now the top bolt should be a peace of cake!!
May be a bit tough now that you have the whole shock out!! but it can still be unbolt, just need more man power or aircompress!!
i don't think he said it was out of the car....did he??....anyway those hex keys strip the holes out very easily....i had to take a ******* hack-saw to mine and chop the ****** off...hahah....it worked tho!
canadian winters kill your car......rust on everything!!!
thanks for all the help guys...
too bad i read majority of the posts after i got it off... i wraped the shaft in a peice of rubber, clamped it w/vice grips and compressed the spring w/ vice grips and used the impact gun to get the top nut off
thank you
btw i love this site, all my q's are answered very quickly... i find my self coming up to the computer inbetween doing things on the car to ask a question.alot of times i have an answer within five mins
bigtime cheers to h-t
thank you
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
seeeya04
Suspension & Brakes
13
Jan 15, 2005 11:39 AM
