Strip Allen Key Hole in Spring
Strip Allen Key Hole in Shock
Hey,
I was changing my stock spring to aftermarket, but on the rear shock the allen key hole was strip a little and I dont want to strip it more . Is there anyway that I could take off the spring without buying new shocks or bringing it to the shop. Thanks for any info giving
Modified by dabiddan at 12:28 AM 10/18/2004
Re: Strip Allen Key Hole in Spring (KiLLa CaM 06)
Cut the dust boot arounf the shock. pull it off and slap a vise grip on the bitch to keep it from turning. I've had to do that with all my older cars.
Re: Strip Allen Key Hole in Spring (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Cut the dust boot arounf the shock. pull it off and slap a vise grip on the bitch to keep it from turning. I've had to do that with all my older cars. </TD></TR></TABLE>
that also damages the strut and voids the warranty..........
Re: Strip Allen Key Hole in Spring (Pioneer162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pioneer162 »</TD></TR><TR><TD CLASS="quote">
that also damages the strut and voids the warranty.......... </TD></TR></TABLE>
You should be changing struts when installing aftermarket springs anyway. But ya if you have a dremel or an air compressor with cut off tool just put a slot into the top and fit a screw driver. I would not recommend the impact wrench idea unless your using a spring compressor.
your smart. So you think putting aftermarket spring aren't going to void the warrentyand damage teh strut. OR EVEN DOING IT YOURSELF. my friend you are an idiot.
Re: Strip Allen Key Hole in Spring (MikeD718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeD718 »</TD></TR><TR><TD CLASS="quote">you could cut a slot across the top of the hole to fit a screwdriver into it.</TD></TR></TABLE>
I will do this from now on though.
your smart. So you think putting aftermarket spring aren't going to void the warrentyand damage teh strut. OR EVEN DOING IT YOURSELF. my friend you are an idiot.</TD></TR></TABLE>
DIY projects don't void the warranty moron, on all struts however the manufacturer's warranty is void if a tool touches the metal shaft of the strut, you can find your facts if you read before calling someone an idiot, you are correct however that after-market springs will destroy stock struts, obviously he should use performance struts, but it appears he doesn't have the cash to do so, or just doesn't want to. Why don't you try being helpfull instead of trying to be the forum badass, it just makes you look arrogent(sp?) and stuipid, and I am NOT your friend, I don't associate with people that have to put other people down to feel good about themselves.
Jaydeep
07-31-2005 03:17 AM
seeeya04
Suspension & Brakes
10
01-16-2005 06:24 PM
