will 215/50/15 rub or not?
Re: will 215/50/15 rub or not? (Miracle_X_Bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar »</TD></TR><TR><TD CLASS="quote">go with the Azenis 215/50/15</TD></TR></TABLE>
They don't come in this size.
I have 205/50/15's on 6.5" wide wheels and my car is only lowered about 1.25". They do rub on full lock a little bit and sometimes in transistions, but not to bad for the most part. I've tried 225/45 and they rub pretty well.
Re: will 215/50/15 rub or not? (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">
I have 205/50/15's on 6.5" wide wheels and my car is only lowered about 1.25". They do rub on full lock a little bit and sometimes in transistions, but not to bad for the most part. I've tried 225/45 and they rub pretty well.</TD></TR></TABLE>
I have had similar experiences. I have 205/50/15s on 6" (I think – they're old TSW EVOs), and it rubs under hard driving (IE autocross). However, I only have Tokico HP shocks and H&R sports (2" drop) – if I had a stiffer setup, it probably wouldn't rub as bad.
...I have 205/50/15's on 6.5" wide wheels and my car is only lowered about 1.25". They do rub on full lock a little bit and sometimes in transistions, but not to bad for the most part...</TD></TR></TABLE>
same here, I had to raise my car to accomodate the Azenis, but for the most part, very little or no rub...as for 215/50/15, i'm thinking it "might" rub...good luck
Re: will 215/50/15 rub or not? (opi)
seems like everyone is going with 205. why don't you guys go with 215? i think there's only $1 difference for kumho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">Azenis dont' come in that size and Kumho's suck.</TD></TR></TABLE>
I wouldn't say Kumho's suck. I've liked the two sets that I've had. Are they as high-performance as the Azenis? No. Will they last longer? Yes, and they'll have better wet traction, too. If you're an avid autocrosser, that's one thing...
Re: will 215/50/15 rub or not? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">go with 205/50/15 </TD></TR></TABLE>
why is that?
why is that?
Re: will 215/50/15 rub or not? (bearboy80)
i rock 205/50/15 azenis on my rota slipstreams for my daily driver...yeah not the best for rain and other weather, last set of tires were kumho's absolutly sucked *** compared to the azenis. overheated really easily not half as much traction as the azenis. and if ur worried about wear...dont drive like a a-hole on a daily basis or drive around wit ur car slammed to the ground wit no camber kit
Re: will 215/50/15 rub or not? (Sushiboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy »</TD></TR><TR><TD CLASS="quote">
I wouldn't say Kumho's suck. I've liked the two sets that I've had. Are they as high-performance as the Azenis? No. Will they last longer? Yes, and they'll have better wet traction, too. If you're an avid autocrosser, that's one thing...</TD></TR></TABLE>
I would. They squeel like a little bitch in the dry, I have seen no advantage over my azenis in the rain (as why my last 3 sets of tires have been azenis), they suck just as bad if not worse in the snow and I only get about 3000 less miles then the Kumho's. Whatever works. If I needed a more streetable tire Bridgestone would be where my money goes.
Powered By Garrett
03-07-2005 08:13 AM
