I tried searching but couldnt find anything.. any help would be appreciated
Old Dec 9, 2003 | 08:15 PM
migitsrcool21's Avatar
Default I tried searching but couldnt find anything.. any help would be appreciated
Anyone have a web link they could send me with walk through instruction for changin out suspention in a 92-95 civic EX/ posibly with pics. I just bought Tokico shocks and struts that drop my car 1.5 inches. This is the first attempt at a suspension install.. any help would be appreciated.
Old Dec 9, 2003 | 09:22 PM
mastarolla's Avatar
Default Re: I tried searching but couldnt find anything.. any help would be appreciated (migitsrcool21)
first off..you bought struts only...
to do the front, jack it up..take off the wheels. you will see the old strut assembly and behind the bottom of the strut is the fork which connects to the control arm. There is a bolt in the back you have to undo..i think a 14mm. Once that is loose, move down that fork to find the bolt at the bottom a 17mm if i remember...undo that, and finally pop ur hood and undo the the 14mm bolts holding the strut to the wheel well. Have a friend step on the brake rotor and push the assembly down and get the strut out any way you can.
The rears work the same way but much easier...undo the top bolts, undo the bolt at the bottom of the strut and i undo the bolt holding the rear lower control arm to the hub i believe....this allows you to push down the control arm to get the strut out.
Old Dec 9, 2003 | 09:24 PM
The Internet Tough Guy's Avatar
Default Re: I tried searching but couldnt find anything.. any help would be appreciated (mastarolla)
here ya go
https://honda-tech.com/zerothread?id=683235
RiTtEk401
26
Oct 18, 2011 02:58 AM
Guin-Teggy
May 22, 2010 01:15 PM
sleeptime
Nov 21, 2007 01:07 PM
Kasper.
17
Jun 29, 2002 10:04 AM
97gs
Mar 28, 2002 06:46 AM
