Everyone i talk to says " i don't know" plz help
Old Dec 9, 2003 | 05:36 PM
Eresuncabron's Avatar
Default Everyone i talk to says " i don't know" plz help
ok. its a noise. in the front.
when i turn the wheel hard over. or go over a bumb
its a deep thick heavy clunking/rattle.
like i can feel it in the floor boards
PLZ HELP
Old Dec 9, 2003 | 05:41 PM
RCautoworks's Avatar
Default Re: Everyone i talk to says " i don't know" plz help (Eresuncabron)
Does it make the noise either way you turn the wheel ? It sounds like its either the left or right inner cv joint.
Old Dec 9, 2003 | 05:44 PM
VtecAddict96's Avatar
Go in a parking lot and turn your wheel all the way to the right/left and go in reverse, if it's the cv joint(s) you'll hear it and it'll be so bad you will have to stop.
Old Dec 9, 2003 | 07:23 PM
Vera's Avatar
Default Re: (VtecAddict96)
i have this prob too .. i believe it is what they are refering to .. the cv joint ... cause ... mine kind of klicks very little .. when i turn left .. so .. ya .. heh ... try turning alot !
Old Dec 9, 2003 | 07:26 PM
USDM 4G VTEC's Avatar
tu eres el cabron!!!!!!
anyways it can be a bad upper ball joint, bad tie rods, bad cv joints , and or lower ball joint... best way is to raise the front tires on the air, and wiggle the tire... it should be stiff and not just wabble around.. depending if it has a wabble is the broken part
Old Dec 9, 2003 | 08:02 PM
biggdogg's Avatar
Default Re: Everyone i talk to says " i don't know" plz help (USDM 4G VTEC)
pinche webon cola .
Old Dec 9, 2003 | 09:33 PM
YumVTEC's Avatar
Default Re: Everyone i talk to says " i don't know" plz help (biggdogg)
i believe the word you are looking for is "huevon"... getting back to the matter at hand, i'd say check the boots on your axles and see if they are ripped and if so if they've lost a lot of grease. if so, then that's probably your culprit. get yourself some autozone axles with a lifetime warranty so when they start clicking again you can get new ones for free.
Old Dec 9, 2003 | 09:36 PM
WongFeihung's Avatar
Default Re: Everyone i talk to says " i don't know" plz help (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i believe the word you are looking for is "huevon"... getting back to the matter at hand, i'd say check the boots on your axles and see if they are ripped and if so if they've lost a lot of grease. if so, then that's probably your culprit. get yourself some autozone axles with a lifetime warranty so when they start clicking again you can get new ones for free.</TD></TR></TABLE>
yep, good advice. check to see if the cv boot is rippe open..and also check to see if there is massive oil spluttered around that aread. haha..im repeating but go to autozone and get a rebuilt axle for about...115 bucks? if you bring your old axle back, they will give you about 55 bucks back. good luck man.
Old Dec 12, 2003 | 11:59 AM
Default Re: Everyone i talk to says " i don't know" plz help (WongFeihung)
ok heres the deal
the cv boots are good.
but that still doesn't rule them out.
but when i jack the car there is no wiggle.
like i said. i don't really kno. so i don't think its broken.
i guess i'll break down and get new cv's
Old Dec 12, 2003 | 01:19 PM
filthyCREX's Avatar
Default Re: (Vera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera &raquo;</TD></TR><TR><TD CLASS="quote">i have this prob too .. i believe it is what they are refering to .. the cv joint ... cause ... mine kind of klicks very little .. when i turn left .. so .. ya .. heh ... try turning alot !</TD></TR></TABLE>
i had that same problem on my 95 coupe.. definatly just needed to change the left axel.
Old Dec 12, 2003 | 01:45 PM
Targa250R's Avatar
be professional
Check tie rod bushings.
all-mtr-teg
Nov 28, 2010 10:22 AM
ld1985
Oct 23, 2009 11:14 AM
1_slow_crx
Sep 10, 2006 08:29 PM
tigueremalo
Jul 14, 2006 04:28 AM
95gsr
Jan 11, 2002 12:35 PM
