CRX FAN PROBLEM
sup yea i just finsih my swap and the car keep over heating after like 20 mins of driving. or what i mean is 20 mins in idle becusae of traffic. the car starts to over heat. not only that but my fan does not work can some one help me out please? thanks.
by circuit im assuming wiring. first check the fuse...then you really cant do a wiggle test...but check the connection on the fan, use a test light or ohm meter. and if you cant figure out the problem...might have to cough up the money to get it checked out.
coool thanks. have u guys ever heard of buying a metel fan and then installing that becuase it works better and its lighter not only that but then u can stick a paper clip into the connector so it remains on all the time?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahayournotfunny »</TD></TR><TR><TD CLASS="quote">coool thanks. have u guys ever heard of buying a metel fan and then installing that becuase it works better and its lighter not only that but then u can stick a paper clip into the connector so it remains on all the time?</TD></TR></TABLE>
Yes, but if your not running a big setup its useless, your stock fan is fine.
You can hard wire the fan to be on when the car is on. There is only 2 wires, power & ground, put the power to the fuse box under the dash.
Attach it to something that is only on when the car is on, like the radio fuse.
vti444
Aug 22, 2007 08:51 AM
