pcv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 »</TD></TR><TR><TD CLASS="quote">why does squeezing the pcv tube shut make clicking sound?</TD></TR></TABLE>
So you know it is working. There is vacuum in that hose and the clicking you hear is the check valve in the PCV valve. If you squeeze it and hear nothing ... it is clogged.
heres a good diagram about how a pcv valve works
http://www.autoshop101.com/forms/h63.pdf
and if you get really silly and want to know more than anyone really should about your pcv system, check out this thread
https://honda-tech.com/zerothread?id=697502
and if you want the quick version....
a pcv valve is a check valve. it only allows flow in one direction. when it is under vacume, it opens up. when you clamp the hose, you remove the vac source. the click is the sound of the valve closing
Evil DOHC
Sep 24, 2001 04:36 PM
