Turbonectics Deltagate (POS) have the same flange as any TIAL?
Old Sep 19, 2001 | 07:57 AM
Thats-so-Ls's Avatar
New User
Default Turbonectics Deltagate (POS) have the same flange as any TIAL?
Im runnin the Rev hard manifold and im currently runnin a Deltagate and i wanna upgrade to a Tial but does anyone know if they use the same flange? And if soo which Tial could i use (part#) and is there any other wastegates that use that same flange (hks,etc. . ) thanks
b18bturbo's Avatar
Default Re: Turbonectics Deltagate (POS) have the same flange as any TIAL? (Hatchypoo)
use the 35mm tial and its the same flange. and everything like a deltagate.
Old Sep 19, 2001 | 11:09 AM
Ray's Avatar
Ray
New User
Default Re: Turbonectics Deltagate (b18bturbo)
does everyone reallly have a bad time with deltagate???
I hear so much complaints about them but mine works fine and many other modded turbo cars use them as well. Rock solid
Old Sep 19, 2001 | 11:41 AM
b18bturbo's Avatar
Default Re: Turbonectics Deltagate (Ray)
its not pos by any means. They do have tendancy to have lot of boost creep at high boost levels copared to the tial. overall they do what they do for 5-7 psi applications
Old Sep 20, 2001 | 11:44 PM
SpeedCon Turbo ZC 619's Avatar
New User
i had a deltagate and it got stuck shut and over boosted my motor and slightly burnt my pistons. now i'm currently rebuilding my motor. i noticed one thing about my deltagate and that is there is a bronze bushing at the bottom of the diaphram where the valve shaft enters it. well that bushing had gotta loose some how and had slip down crooked cuzing the shaft to bind, not allowing it to move freely. so when i found that out, i started to checking out other deltagates and they were designed different. the bushing was still there but now it was installed from the inside so it cant fall out like mine did.
i think the deltagates are fine for under 10 psi. over that you my want to extra security of a quicker responding higher air flowing wastegate. plus Tail offers them in stainless steel for a reasonable price.
Fatty_1775
Feb 7, 2006 11:32 AM
T25So
Dec 22, 2005 03:07 PM
5STAR3
Aug 7, 2003 04:23 PM
doughboy247
Aug 25, 2002 09:29 PM
DamonBoost
Oct 29, 2001 01:32 PM
