direct port and plate system wats difference?
ok i don't know much about nitrous so wats the difference between these two...i know direct port is sprayed directly into each port in the manifold but wat is wet plate system?? someone fil me in.
Plate system is only for GSRs.
It goes in between the 2 pieces of the intake manifold where the secondary butterflies are. Direct port usually involves drilling holes in each intake runner. The plate system is basically a short-cut direct port for the GSR.
Dustin
Dustin
so how does that work? does it still spray in the manifold? how many jets are spraying there? and wat is puddling and will it be a problem? how to fix it?
EGh22aEG
Mar 13, 2002 10:46 AM
