Replacing my deltagate with a tial today.. a few questions...
New User
-Art was telling about this way to hook up the ebc to my tial by using the side port? How do you do this? Do i just hook the same lines that i will unhook from my deltagate to my new tial in a similar fashion?
-Also my tial didnt come with any instructions. I got these two metal flange looking pieces in it. Do I use these and where and how?
-The ring that comes with it, I put the smaller end inside the wastegate right? and then just mount that flush on top of the manifold?
Thanks guys...
Thanks guys...
Re: Replacing my deltagate with a tial today.. a few questions... (Damon501)
you have the 1st/2nd answers right. You should only have one metal flange the rest should be the gaskets, i could be mistaken, you can use the metal flange to fabricate a dump tube later on.
thanks man.. so i can just hook my profec b to the side port?
New User
Re: Replacing my deltagate with a tial today.. a few questions... (LsTurbo91)
hey man whats up.. thanks for all the replys.. In my profec b instructions it told me to hook the line up that you are talking about going to the compressor housing to the intake manifold? Is that not correct? I am also curious if I was supposed to put the little ring in there that goes between the bottom of the wastegate and the exhaust manifold if I am using an electronic boost controller. As of right now I had to turn both the sharp setting and the low boost setting all the way up to get almost 8lbs of boost.. It is a 35mm Tial wastegate too.. thanks again...
SilverS
07-24-2002 09:29 PM
