Honda S2000 Honda S2000
who makes high compression pistons for the S-2000 ??
Old Dec 8, 2003 | 09:57 AM
douglas_be's Avatar
Default who makes high compression pistons for the S-2000 ??
I want more copression in my S-2000, who makes them ?
Thanks
Old Dec 8, 2003 | 11:13 AM
S2KandSTi's Avatar
TODA will have 12.5:1 pistons in their stroker kit, JDM pistons coupled with a JDM head gasket will raise compression to 11.7:1 and you can get custom pistons from companies such as JE.
Old Dec 8, 2003 | 11:51 PM
profpin's Avatar
Default Re: (Kikomon)
why not just get some spoon or mugen headgasket????/
Old Dec 10, 2003 | 05:22 PM
Miracle_X_Bar's Avatar
Default Re: (profpin)
GO TODA!!!
Old Dec 10, 2003 | 09:22 PM
Racer_EH's Avatar
who makes 13:2???
Old Dec 10, 2003 | 09:53 PM
Champ R's Avatar
Default Re: who makes high compression pistons for the S-2000 ?? (douglas_be)
If you arent doing anything too radical, id look into those JDM s2k pistons and the headgasket as someone already mentioned. Nothing like stock OEM parts.
Old Dec 10, 2003 | 11:35 PM
evil vapor's Avatar
Default Re: who makes high compression pistons for the S-2000 ?? (Champ R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champ R &raquo;</TD></TR><TR><TD CLASS="quote">If you arent doing anything too radical, id look into those JDM s2k pistons and the headgasket as someone already mentioned. Nothing like stock OEM parts.</TD></TR></TABLE>
at a good price too, the pistons are cheap and may not be easy to come by. Get in touch with JE dealer, you can get custom pistons made, but why? Are you building a track motor?
Old Dec 10, 2003 | 11:52 PM
douglas_be's Avatar
Default Re: who makes high compression pistons for the S-2000 ?? (vapor)
Yes, you got it . The engine is used for trackracing ( 4 hours per heat). This engine sits in a 1994 Civic 3 doors , hooked up to a 6-speed gearbock of the Euopean 2002 Civic type "R" (same gearbox as the RSX type S). The car is flying , but it can always be something more ! Jeff at IB offered me a set for $600.00
Old Dec 11, 2003 | 12:06 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douglas_be &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you got it . The engine is used for trackracing ( 4 hours per heat). This engine sits in a 1994 Civic 3 doors , hooked up to a 6-speed gearbock of the Euopean 2002 Civic type "R" (same gearbox as the RSX type S). The car is flying , but it can always be something more ! Jeff at IB offered me a set for $600.00 </TD></TR></TABLE>
must sound like a handful to drive! Do some more research about Jeff at IB before making a final purchase. Be sure you know what you're getting. Honestly, if I was in your shoes since you'll have the head off, resleave the block and bore it out to 2.2L spec, keep compression low, 11.5:1 and you'll have a more reliable engine and make more power at the same time. Don't reduce the stroke.
Old Dec 19, 2003 | 09:00 PM
omega11855's Avatar
i have pistons from jeff and find him very reputable so i have no idea why u would make that kind of a remark? 12.8:1 in my b18c :D
Old Dec 20, 2003 | 11:29 AM
douglas_be's Avatar
Default Re: (omega11855)
I just ordere a piston kit with Jeff IB
takes abouth 4 weeks !
Old Dec 21, 2003 | 11:45 AM
71 mgb's Avatar
Default Re: (douglas_be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douglas_be &raquo;</TD></TR><TR><TD CLASS="quote">I just ordere a piston kit with Jeff IB
takes abouth 4 weeks !</TD></TR></TABLE>
those pistons will be a great adition
riceball777
Jan 21, 2014 09:49 AM
stonet149
12
Nov 2, 2008 09:29 PM
team 15
Jun 22, 2007 03:49 AM
BLK99VTECR
Jan 19, 2005 06:40 PM
ArinX
Honda S2000
Oct 23, 2004 07:40 PM
