Help: Something different between my 2000 and 2001 ITR block
Old Dec 8, 2003 | 03:28 AM
PM-Performance's Avatar
Default Help on my 2000 Itr block to my 2001 ITR block . something diff.
ok i was looking at pics of my old 2001 block and noticed the sensor on cyl 3. look below, i think the knocksensor?
now my 2000 itr block doesnt have that ? they weren't equipped with knocksensors? Also there is a port above the water tube thats open on my 00 block , but on my 01 block looks like a black hose on it ? was that for the PCV system? if so , does anyone know the size and pitch of the hole so i can plug it up . This freaking block is a nightmare.
Old Dec 8, 2003 | 03:31 AM
That Dood's Avatar
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (itr206)
both have knock...and tube is pcv systems.
edit....
Modified by That Dood at 10:46 PM 12/8/2003
Old Dec 8, 2003 | 03:37 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (That Dood)
if i dont have that oil cooler box anymore, can i just plug it up ?
does the knock sensor plug go thru the block? or just threads in and senses from vibration or something ? from what i remembered from looking at the 00 block it didnt go thru the block . I guess i dont really need it becuase the Hondata doesnt recognize the knock sensor correct?
Old Dec 8, 2003 | 03:38 AM
2k1_ITR_0736's Avatar
correct, hondata doesnt need knock sensor.. last i kne when i pulled out a knock sensor it had some oil on it...
Old Dec 8, 2003 | 03:43 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (2k1_ITR_0736)
hmmmm ,from looking at it the only open hole to the internals was this oil cooler hole?
Old Dec 8, 2003 | 03:48 AM
Asahi's Avatar
Hondata will use a knock sensor if your ECU is capable of sensing one. P28 ECU is not capable but a P72 is.
Old Dec 8, 2003 | 03:54 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (Asahi)
i run the P28, any info on the size and thread to plug these holes? is it ok to plug the oil cooler hole?
Old Dec 8, 2003 | 05:01 AM
00 FBP ItR's Avatar
its not a for the oil cooler, its for PCV.
Old Dec 8, 2003 | 05:05 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (00 FBP ItR)
It goes to the black box on the back of the block from what i remember , that is the oil cooler. i think that line and the line from the PCV went to that box? I dont remeber though, its been sooo long since i messed with this thing. I still have my orig box, but i took it out and am using the Endyne catch can set up.
Old Dec 8, 2003 | 07:27 AM
ArmyGreenITR's Avatar
I dont think the oil cooler has a line that goes into the black box.i thought that was only the PCV.
Old Dec 8, 2003 | 07:47 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (ArmyGreenITR)
the oil cooler is the black box ?No?
Old Dec 8, 2003 | 07:55 AM
Eluder200K's Avatar
No, the "black box" is for the PCV system. The oil cooler is just a heat exchanger with coolant lines that go in and come out of it.
Old Dec 8, 2003 | 08:01 AM
Default Re: Help on my 2000 Itr block to my 2001 ITR block . something diff. (Eluder200K)
ok ., now what does that look like? i dont remember anything else going into the back of the block .
Old Dec 8, 2003 | 08:04 AM
Evan , this is a pic you sent me before i just noticed. this was when i was asking about the Alternator brakcet.
Old Dec 8, 2003 | 08:13 AM
Eluder200K's Avatar
haha, yup, I was just about to post that. The oil cooler is just a thing around the base of the oil filter. It has a little water line that goes too and from it that allows coolant to flow through to take some of the heat out of the oil and deposit that heat into the main coolant system.
The 2 big fat rubber lines in that pic are the water lines that feed the oil cooler. I think the black box is just a baffle or a charcoal can for the PCV system.
Sounds like someone needs a shop manual... is Santa bringing one this year?
Old Dec 8, 2003 | 08:22 AM
i have a manual , but its not very helping , it dont show this stuff.
its a junk one.
Anyway can i plug that hole? or route the line anywhere else? I looks like it runs right into the black box?
Old Dec 8, 2003 | 08:39 AM
Eluder200K's Avatar
I'm not 100% sure. I guess it depends how you have your catch can hooked up. You said you didn't have the box hooked up on your old block when you were using a catch can?
Old Dec 8, 2003 | 08:42 AM
no on the old block everything was hooked up as stock with the PCV system . Now with the new block the guy was running the Endyne catch can and this port was open .
Old Dec 8, 2003 | 02:01 PM
nice dart block....
Old Dec 8, 2003 | 02:02 PM
thats notmy block
Old Dec 8, 2003 | 04:05 PM
Eluder200K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k1_ITR_0736 &raquo;</TD></TR><TR><TD CLASS="quote">nice dart block....</TD></TR></TABLE>
haha, you wish
I wish someone would reply to this post and help out Pete, did you try the FI board too?
Old Dec 8, 2003 | 05:06 PM
i guess not a big deal . i plugged the hole with an extra 1/8NPT plug i had sitting around , i just tried it and it worked.
thanks anyway
safedriver
Feb 20, 2011 02:28 PM
dls_tech
Dec 11, 2010 07:36 AM
slowteg550
Jun 27, 2006 04:35 PM
PM-Performance
Dec 8, 2003 10:29 AM
Si Erik
10
Dec 6, 2003 06:00 PM
