corrosion on piping what do i do?
Old Dec 7, 2003 | 02:35 PM
speedehatch's Avatar
Default corrosion on piping what do i do?
Whats the best thing to do if there is some corrosion on exhaust piping, hi temp painting the piping will help maybe?
Old Dec 7, 2003 | 02:44 PM
monicle's Avatar
Default Re: corrosion on piping what do i do? (speedehatch)
get some rust away stuff spray it on there then after about 20 minutes use a 100 grit or a 220 grit to sand away the rust. then immediately spritz it with some paint.
Old Dec 7, 2003 | 02:49 PM
Debaser's Avatar
A wire brush attached to a drill will be way easier than sandpaper.
Old Dec 7, 2003 | 03:32 PM
joecivic93's Avatar
Default Re: (Debaser)
remove any loose rust with wire brush then hand sand (doesnt have to be perfect), next clean pipe with solvent,then use Rustoleum BBQ black cause it has a primer already in it and you dont want a ton of paint on it anyhow.spray a few light coats of paint and you are DONE!
Noteverspray sucks,if you dont want paint on it cover it up,plastic works great you can also use tarps,garbage bags,or newspaper,just remember that paper will absorb paint and it can bleed through.
Old Dec 7, 2003 | 03:42 PM
Default Re: (joecivic93)
so basicly im to remove the rust with sandpaper and some rust removal spray. Then repaint the section? I was planning to recoat the piping anyways so thats no big deal.
Old Dec 8, 2003 | 06:31 AM
monicle's Avatar
Default Re: (speedehatch)
yep you got it.
93grayeg
Dec 17, 2012 07:06 PM
rdssk8rcs1
Feb 21, 2008 09:09 PM
Tyte-S
Paint and Body
Feb 16, 2008 08:37 AM
digitalVinyl
Aug 5, 2006 06:17 PM
Diego Boost
Feb 28, 2004 01:40 PM
