Starting to work on my engine... b18c
Old Dec 7, 2003 | 08:56 AM
95DXPhiladeph's Avatar
Default Starting to work on my engine... b18c
So I got my JDM b18c in, and I know alot of you saw the pics... I plan to rebuild alot of this engine... atleast the block and transmission while it's out of the car... then I plan to do the rest while it's already dropped in...
So what I'm asking is right now as it sits straight from where I got it, what can I begin to do? Where would you start?
Can I start by unplugging the wiring harness? How am I going to know how my DX harness plugs back in? I have the wiring sub-harness from HASport for the VTEC, so I'm okay.
What else can I do? Water pump? Timing belt? Spark plug, wires, cap, rotor?
Just basically trying to get opinions on what people would do in my position right now. I will be rebuilding alot, but I'm not ready to send the block in or anything just yet... but soon.
THANKS!
Old Dec 7, 2003 | 08:59 AM
SleepnCiViC's Avatar
starrt by giving it a tune up if need be!! all the little neccesities, then go from there
Old Dec 7, 2003 | 09:10 AM
More specifically, tune up and neccessities?
Like... I don't wanna put any fluids in there right now, so what do you mean?
Old Dec 7, 2003 | 09:46 AM
Default Re: (95DXPhiladeph)
top
Old Dec 7, 2003 | 09:59 AM
pdiggitydogg's Avatar
new timing belt, water pump for sure
new plugs and wires (seriously concider rotor and cap for the dist.)
lol same things you listed, I just noticed
Old Dec 7, 2003 | 10:07 AM
JV's Avatar
JV
Who?
Default Re: Starting to work on my engine... b18c (95DXPhiladeph)
Your question is alittle vague.
What is your definition of "rebuilding" the motor and tranny?
Do you plan on replacing the internals? Or are we talking a basic tune up?
Old Dec 7, 2003 | 11:43 AM
Default Re: Starting to work on my engine... b18c (JV)
i plan on replacing pressure plate, flywheel, whole clutch assembly basically...
the block will have pistons, rods, rings, and sleeve it.... 3 angle valve job... rod bolts... um... that type of stuff...
a serious build up.. but not like EVERY LITTLE THING... you know?
Old Dec 7, 2003 | 11:44 AM
pdiggitydogg... that's cool.. you reccomend getting beefed up plugs and wires and all... i plan to turbo later too...
anyone got brands they like for any of that? plugs, cap, rotor, wires?
Old Dec 7, 2003 | 11:49 AM
FrostySol's Avatar
I'm assuming that if you're gonna go turbo you're not going with high comp pistons right? When you've got the head off you can replace the head gasket and all. I'd mainly make sure everything you've got allready works like it's supposed to so that when you drop in your new motor you don't end up with something broken
Old Dec 7, 2003 | 12:17 PM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DXPhiladeph &raquo;</TD></TR><TR><TD CLASS="quote">i plan on replacing pressure plate, flywheel, whole clutch assembly basically...
a serious build up.. but not like EVERY LITTLE THING... you know?</TD></TR></TABLE>
IMHO you should start off by getting yourself a Helms, and doing some research into what it takes to rebuild an engine. (tear down, machining, parts, assembly, etc.)
Try searching around the Forced Induction and Allmotor forums. Look for people doing similar types of buildups and ask questions.
The more knowledge you gain, the easier it will be for you to make an educated decision on what, and when things need to be done...
Good luck.
Old Dec 7, 2003 | 12:32 PM
awesome thanks alot... know any good FI forums for H/A?
Thanks again...
Old Dec 7, 2003 | 12:37 PM
JV's Avatar
JV
Who?
https://honda-tech.com/zeroforum?id=16
https://honda-tech.com/zeroforum?id=44
Hayden_Fourroux
Feb 2, 2016 09:01 PM
D166thgen
Jun 5, 2006 10:22 AM
RS DC4 94
Feb 7, 2006 11:21 PM
zm_dawg
Jul 7, 2004 12:09 PM
95DXPhiladeph
Dec 8, 2003 12:12 PM
