I have a question/problem....about my o2 censors.
Old Dec 7, 2003 | 01:23 AM
00EM1Si's Avatar
Default I have a question/problem....about my o2 censors.
Well I have this problem with my check light going off when I installed my skunk2 stage 1 cams. The code thats been coming up is the o2 censor... A friend of mine told me to clean both of my o2 censors with carb cleaner and then the check engine light should stop...does anyone know if this is true or had this happened to them? any feedback will help thanxs
Old Dec 7, 2003 | 03:04 AM
blackhatchy's Avatar
Default Re: I have a question/problem....about my o2 censors. (Krazipeenoi)
whay code is it exactly?
Old Dec 7, 2003 | 03:12 AM
TeStUdO's Avatar
Default Re: I have a question/problem....about my o2 censors. (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">whay code is it exactly?</TD></TR></TABLE>
If you are throwing code 1 just replace O2 sensors, it will be better in the long run
Old Dec 7, 2003 | 03:19 AM
Default Re: I have a question/problem....about my o2 censors. (TeStUdO)
reason i ask is because if it is a code 41 then it is a curcuit fault, he could have sliced a wire.
Old Dec 7, 2003 | 03:27 AM
JDMlyfestyle's Avatar
Ive heard that carb cleaner will ruin the O2 and the CEL will stay on
Old Dec 7, 2003 | 05:24 PM
00EM1Si's Avatar
Default Re: (JDMlifestyle)
thanxs for the replies...ill check what code its comming out ill update thanxs
Old Dec 7, 2003 | 06:04 PM
upgraded's Avatar
They make o2 sensore safe carb cleaner. get that
Old Dec 8, 2003 | 12:28 AM
00EM1Si's Avatar
Default Re: (upgraded)
thanxs
Old Dec 8, 2003 | 12:34 AM
ace1875's Avatar
Default Re: (Krazipeenoi)
you can use just plain gas and an old tooth brush to clean it
Old Dec 18, 2003 | 12:52 AM
00EM1Si's Avatar
anything else?
Old Dec 18, 2003 | 02:06 AM
slammed_93_hatch's Avatar
yes when and if you do replace ur O2 sensor, get a good one i didn't want to spend the money (300) for an OEM one from kragen so i got one for 75. guess what its **** and doesn't work, i got another one(didn't pay for it though my friend works at kragen and he hooked it up) because of the CEL still being on. Yep again that one kept on throwing a CEL too. I was going to purhcase a denso one but they are on back order from Denso, so i went with a Warrner i think (o2sensor.com said they are both the same). the warrner one was like 125 i think. If this one continues to give me a bad O2 sensor reading im gona be soooo pissed, cause that means that not only will i have to wait on geting my car BAR'd but i will also have spent over 300 dollars on O2's and alot of wasted time. So ill be the gini pig and see if the warrner one is good. if it is then good if not then buy the OEM one
schweiger
Oct 23, 2012 05:38 PM
Spug
May 26, 2012 12:15 AM
JD95hatch
May 18, 2006 02:51 PM
spencedogg
12
Nov 30, 2003 11:57 AM
94civic2nv
Oct 6, 2003 04:00 PM
