NEED INFO on 99 b16a2 tranny? hard to get in 1st sometimes
Old Dec 6, 2003 | 10:26 PM
G U E C O's Avatar
Default NEED INFO on 99 b16a2 tranny? hard to get in 1st sometimes
hey guys is it just me or are u guys experencing trouble getting into first gear with your 99 b16a2 tranny. i was told there was a recall on the 99 b16a2 tranny, but i cant find info on it.
please dont post, no i am not having problems with my gsr, first gen b16, itr, sohc, etc. trannies. ONLY b16a2
PLEASE HELP
Old Dec 6, 2003 | 10:42 PM
clm's Avatar
clm
Default Re: NEED INFO on 99 b16a2 tranny? hard to get in 1st sometimes (stock93cx)
IIRC there was a recall/TSB on the synchros for the Sis, but I don't think it was for 1st gear. Try taking your foot of the clutch and putting it back in and trying if you haven't already.
I'll try to find a link to recalls and TSBs.
EDIT: The link to recalls and TSBs;
http://www.nhtsa.dot.gov/cars/problems/
Old Dec 6, 2003 | 10:51 PM
G U E C O's Avatar
Default Re: NEED INFO on 99 b16a2 tranny? hard to get in 1st sometimes (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">IIRC there was a recall/TSB on the synchros for the Sis, but I don't think it was for 1st gear. Try taking your foot of the clutch and putting it back in and trying if you haven't already.
Ya i release the clutch slowly while im in neutral and try to put it in 1st, sometimes i get in and most times it dont. Sometimes i need to shift to 2nd then 1st, but most of the time it doesnt work so i have to go in 2nd. My 3 friends are also having the same problems with the tranny.
Old Dec 6, 2003 | 11:53 PM
G U E C O's Avatar
bump for night
Old Dec 7, 2003 | 12:03 AM
IWearMyKswiss's Avatar
New User
you said it yourself,.you already do the things to get into first gear,..ive never heard anything on recalls for that particular tranny though,..sometimes its hard to get into first with my LS tranny,...but thats only when its really cold outside
Old Dec 7, 2003 | 01:16 AM
G U E C O's Avatar
Default Re: (WiDeBoDyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK &raquo;</TD></TR><TR><TD CLASS="quote">you said it yourself,.you already do the things to get into first gear,..ive never heard anything on recalls for that particular tranny though,..sometimes its hard to get into first with my LS tranny,...but thats only when its really cold outside </TD></TR></TABLE>
it only works sometimes, its getting worst and worst evey time i drive it. anyone know a solution to this? is this only my b16a2 tranny?
Old Dec 7, 2003 | 03:58 AM
SRT-WHORE's Avatar
Default Re: (stock93cx)
I thought I was the only one experiencing this problem on my D-series tranny. Does it from time to time but mainly when the clutch isn't fully depressed. Never heard of any recall for that.
Old Dec 7, 2003 | 08:04 AM
clm's Avatar
clm
Default Re: (SILINITY16)
Have you tried changing the transmission fluid with some fresh Honda MTF?
Old Dec 7, 2003 | 11:35 AM
G U E C O's Avatar
Default Re: (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried changing the transmission fluid with some fresh Honda MTF?</TD></TR></TABLE>
yes
Old Dec 7, 2003 | 01:01 PM
eg6h8k's Avatar
put in some gm synchromesh(friction modify) and post back..it helped my tranny a great deal...
Old Dec 7, 2003 | 02:34 PM
80884's Avatar
Default Re: (eg6h8k)
yea try a better tranny fluid, i like how every one praises the honda mtf as being the best ...I know of two that are better already, the GM stuff and also the royal purple MTF works great, i noticed smoother shift right after I put this stuff in. "USED to run honda mtf"
Hows the clutch? my car did this once when i was at the track and my clutch was going bad. put in new clutch and was fine ever since....Note to self - Stock honda clutch and nitrous don't go good together. my tranny - 00 si b16a2
Old Dec 7, 2003 | 03:10 PM
G U E C O's Avatar
will try the gm, and it has a brand new excedy organic clutch. yes everything was installed right
JDMroyEG5turbo
Feb 22, 2006 09:27 AM
migs
Aug 22, 2005 05:41 PM
AZNBIGPIMPN505
11
Dec 17, 2004 11:01 AM
zman
Aug 28, 2004 01:58 PM
