PCV performance?
Old Sep 18, 2001 | 10:56 AM
976's Avatar
976
New User
Default PCV performance?
I have read people removing there positive crankcase ventilation valve. What are they doing, putting a breather insted, what performance can come from this - just a constant ventilation?
Old Sep 18, 2001 | 01:55 PM
rioninja's Avatar
Default Re: PCV performance? (B21A)
No, there is actually more ventilation when you leave it stock. But, have you ever looked into your throttle body? Most of the oil and grime is a result of oily vapors. I really dont know about any advantages/disadvantages besides that.
Old Sep 19, 2001 | 12:16 PM
976's Avatar
976
New User
Default Re: PCV performance? (RioNinja)
Yeah, that is what I figured. Thanks for clearing it up...
Old Sep 20, 2001 | 06:07 AM
Davep's Avatar
Don't remove the valve you need the positive crankcase ventilation.
Old Sep 20, 2001 | 07:25 AM
Big James's Avatar
New User
Default Re: PCV performance (Davep)
I have seen domestics route it to the exhuast that way it is pulled out by the exhaust and said to give more power.
any opinions?
Old Sep 21, 2001 | 03:53 AM
Davep's Avatar
Default Re: PCV performance (Big James)
I don't know about that. I run a catch can between the PCV and the intake manifold to catch the oil.
Old Sep 21, 2001 | 05:43 AM
92CivicSiR's Avatar
New User
If you remove the PCV system you will notice that the car will blow smoke quite a bit.
Old Sep 21, 2001 | 11:10 PM
Grandprix's Avatar
Default Re: PCV performance (92CivicSiR)
so if your pcv valve is broken you will be burning more oil than normal???
Im just asking because is burning quite a bit of oil, and Im in denial about the rings going bad
Old Sep 22, 2001 | 05:40 AM
92CivicSiR's Avatar
New User
Default Re: PCV performance (Grandprix)
If your PCV valve is bad then it will burn a little oil, but if you totally remove the system then it will smoke quite a bit.
Old Sep 23, 2001 | 12:33 AM
ILOVEGIRLS's Avatar
which tube do you pull out for the catch can?
so simple
May 11, 2010 11:49 PM
so simple
May 1, 2010 05:32 PM
HondaCutter
Nov 24, 2006 04:28 PM
dpkelly
Aug 15, 2005 08:52 PM
