Will this fit? toda header + godspeed test pipe + stock exhaust
Old Sep 18, 2001 | 10:51 AM
Black R's Avatar
25 Year Member
Default Will this fit? toda header + godspeed test pipe + stock exhaust
On an itr?
What gasket's do I need on the intake side and exhaust side?
Thanks!
Old Sep 18, 2001 | 10:52 AM
Digital-R's Avatar
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (Black R)
Yeah it fits if you weld 2inches off the t-pipe. I have almost the same setup, except for a 5zigen catback.
Old Sep 18, 2001 | 10:55 AM
Black R's Avatar
25 Year Member
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (Digital-R)
Old Sep 18, 2001 | 11:01 AM
RATEDR's Avatar
I think Mr Rocker is asking if you can use the 95 GS Legend exhaust gasket on the Toda collector where the
test pipe will mate to or is there another gasket that is needed?
Old Sep 18, 2001 | 11:06 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (RATEDR)
Jason (DarthVadeR) has a Toda header. Not sure which cat he's using (should have the same flange as Dan's test pipe). Shoot him an IM.
Old Sep 18, 2001 | 11:12 AM
Kengs's Avatar
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (itr009)
Kenny,
If you need the Legend donut gasket, I have an extra one in the garage.
Digital-R's Avatar
I am using the same gasket that I had with my JDM. The Legend gasket would do as well.
Old Sep 18, 2001 | 11:17 AM
Black R's Avatar
25 Year Member
And what gasket were you using for the jdm header?
*goes to im both kengs and DarthVadeR*
Thanks for the clarification TJ!
ttt
Old Sep 18, 2001 | 11:20 AM
R1020's Avatar
ken, you'll also need the 2.5" to 2.25" 'reducer' from SMSP. i just put one on my stock exhaust to connect to my 2.5" cat. love it!
i believe jason (darth vader) has one as well?
[Modified by R1020, 3:20 PM 9/18/2001]
Old Sep 18, 2001 | 11:24 AM
Splat's Avatar
Part numbers Type R. Donut gaskets for use with 2.5" collector headers.
Acura (from an early 90's Legend coupe) - 18229 SPO J51
Honda (from the S2000) - 18229 PCX 003
Old Sep 18, 2001 | 11:32 AM
Black R's Avatar
25 Year Member
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (R1020)
I don't care about the reducer. This is just a temporary thing until I get an exhaust figured out. Obviously a good one will be used. Stocker will remain whole in case I decide to go back to all stock.
Pat, thanks for the part #'s.
I'd still like to hear from darth...
Old Sep 18, 2001 | 11:42 AM
R1020's Avatar
ah, okay. i'm not sure if the stock b-pipe will bolt up the a test pipe, depends on the flange used on the test pipe.
good luck with it!
Old Sep 18, 2001 | 11:55 AM
Dipshit Dan's Avatar
Yes it will but you'll need the aforementioned Legend gasket which is also the gasket used on the JDM Integra.
Old Sep 18, 2001 | 12:00 PM
Black R's Avatar
25 Year Member
Default Re: Will this fit? toda header + godspeed test pipe + stock exhaust (God)
*.....the r0cker does a little more post whoring for today:*
ok, so what about between the test pipe and the stock exhaust? just a generic mr gasket from pep boys?
Old Sep 18, 2001 | 12:13 PM
Splat's Avatar
Unless Dan makes his test pipe with different inflow and outflow sizes, you will need to have some sort of mate between the stock b-pipe and test pipe made. I had mine installed by a muffler shop near town. He cut a couple of inches off the stock b-pipe, and welded up a larger diameter pipe with a standard flange to fit my Jeg's 2.5" cat.
Is Dan's test pipe 2.5/2.5 or 2.5/2.25?
Old Sep 18, 2001 | 12:41 PM
Black R's Avatar
25 Year Member
his website says it will fit on aftermarket or stock exhausts...
http://godspeed.hack.net/
Old Sep 18, 2001 | 12:54 PM
RATEDR's Avatar
The godspeed test pipe will fit the Stock exhaust...I just bought a 2.5" Universal Mr. Gasket from Advanced Autoparts.
Works fine!
Old Sep 18, 2001 | 03:45 PM
Back in Black's Avatar
Rather OG
Ken~
Sorry I didn't see this sooner
Current setup= Toda Header + Carsound 94006 (2.5") Cat + SMSP Adapter + Tanabe Racing Medallion exhaust.
in my opinion
dcdcdc
Jul 13, 2006 05:23 AM
jbell
Apr 14, 2005 09:53 PM
Stinkycheezmonky
Sep 30, 2004 10:23 AM
sicklexus1
Feb 25, 2003 11:29 AM
