Benefit of CTR intake cams for the integra R
Old Sep 18, 2001 | 06:54 AM
R-Adrenaline's Avatar
New User
Default Benefit of CTR intake cams for the integra R
What are the benefits of swapping out ITR intake cams for CTR intake cams?
Old Sep 18, 2001 | 06:58 AM
Dropspeed's Avatar
Default Re: Benefit of CTR intake cams for the integra R (R-Adrenaline)
Its not worth pulling a ITR cam to replace with a CTR cam. With a cam gear tuned on a ITR cam you can easily get the same increase.
Mattj
Old Sep 18, 2001 | 07:05 AM
New User
Default Re: Benefit of CTR intake cams for the integra R (Dropspeed)
that is my point....what benefit would you get from swapping out any ITR parts for CTR parts?
Old Sep 18, 2001 | 07:18 AM
Dropspeed's Avatar
The first post was a question, your second your making a point???? What other parts specifically do you want to know about?
Old Sep 18, 2001 | 09:55 AM
New User
Any....what benefits would you get from swapping out any parts?
Old Sep 18, 2001 | 10:02 AM
Type Goch's Avatar
New User
well swapping for the CTR Pistons would increase your CR significantly..
Old Sep 18, 2001 | 10:04 AM
SpecR_EK's Avatar
New User
Default Re: Benefit of CTR intake cams for the integra R (Type Goch)
Aren't the cams of the 00-01 ITRs basically the same spec as the CTR cams?
Old Sep 18, 2001 | 10:24 AM
CPR's Avatar
CPR
Default Re: Benefit of CTR intake cams for the integra R (SpecR_EK)
Someone replied that swapping out the ITR cams for CTR cams will yield almost identical results as using cam gears to tune the ITR cams.
I think the question is what are these results? I would like to know as well since I'm thinking about getting some cam gears for my otherwise stock car.
Old Sep 18, 2001 | 10:37 AM
TypeC's Avatar
people say that, but no one has mic'd them, so no one knows for sure.
Old Sep 18, 2001 | 10:45 AM
travis's Avatar
Default Re: Benefit of CTR intake cams for the integra R (TypeC)
The CTR cams differ from the ITR cams by 3 degrees on the VTEC lobe on the CTR intake cam. That's it. The overall gains will likely be less than the WHP difference between summer and winter ambient temps. Hardly worth the effort, IMHO.
Old Sep 18, 2001 | 12:06 PM
Mike K's Avatar
Default Re: Benefit of CTR intake cams for the integra R (ITR#231)
I have miced the cams at a local machine shop and they all have the same lift.
Duration on the CTR cam is approx. 3 degrees more than a 98.
Duration on the 00/01 ITR cam is approx. 1-2 degrees more than a 98.
-Mike K
JDMlyfestyle
Nov 1, 2003 06:26 PM
Quiks66
Oct 31, 2003 05:40 PM
thrty8street
Oct 27, 2003 07:44 AM
498GSR
Oct 28, 2002 10:06 PM
Trajic
Jul 11, 2001 07:28 PM
