valve settings for turbo???
Old Dec 5, 2003 | 11:42 AM
djnikko's Avatar
Default valve settings for turbo???
is there any advantage to changing the honda specified valve clearances on a turbo converted zc? just a thought.... anyone tried it? if so what were the results?
Old Dec 6, 2003 | 08:50 AM
djnikko's Avatar
Default Re: valve settings for turbo??? (djnikko)
bump!
Old Dec 6, 2003 | 09:54 AM
djnikko's Avatar
the valves im meaning are under the tappets, the engine is DOHC. I thought maybe widening the valves may help turbo cars??? especially on the intake side
Old Dec 10, 2003 | 12:44 AM
djnikko's Avatar
anyone??
Old Dec 10, 2003 | 01:50 AM
vti2's Avatar
iff you have bigger valves at the exhaust side will the gases flow faster, and you can get some extra hp with that.
Old Dec 12, 2003 | 01:23 AM
djnikko's Avatar
Default Re: valve settings for turbo??? (vti2)
how much bigger thou? in theory it would mean a bit more HP, not loads thou. would it kind of fool the engine into thinking it had lower compression cuz the enterance and exit is bigger so to speak?
Old Dec 12, 2003 | 04:23 AM
djnikko's Avatar
bump!
Old Dec 12, 2003 | 06:07 AM
p0gi's Avatar
I would leave it stock. If you make close the gap you run the risk of the pistons hitting the valves. If you open the gap you are decreasing the lift and duration and your engine will begin to get noisy because of the harsh contact of the cam to rocker arm.
Old Dec 16, 2003 | 11:03 AM
djnikko's Avatar
Default Re: valve settings for turbo??? (p0gi)
ok thanks for the reply i'll just leave it as it is
almostjdmeg
Oct 15, 2008 08:38 AM
WalkerGSR1
Jan 11, 2007 11:16 PM
Garcia-Racing
Dec 24, 2003 07:05 PM
porsche997dc2
Jun 26, 2003 09:45 PM
fastludeh22
Aug 10, 2002 12:27 PM
