supertech flat faced valves good for turbo?
Old Oct 14, 2008 | 05:23 PM
almostjdmeg's Avatar
Default supertech flat faced valves good for turbo?
I have a gsr head completely redone, it has supertech flat faced
valves and valvesprings. Are these good to use on a FI motor? Or are these better for NA?
Old Oct 14, 2008 | 08:25 PM
SD_Lurker's Avatar
HT White Ops
Default Re: supertech flat faced valves good for turbo? (almostjdmeg)
Better for NA but they will work. The flat valves tend to bump the CR up a slight bit.
Old Oct 15, 2008 | 04:38 AM
turbotypeR@SPEC's Avatar
25 Year Member
they are working great in my car
Old Oct 15, 2008 | 08:38 AM
HiProfile's Avatar
With NA apps, you want as high a CR as you can get with your gas. WIth boost, CR really doesnt matter, at least its not as cruicial. I'd rather not have flat-faced valves, as they are heavier. There is a smaller chance of floating a valve if you rev it really high, although valve failure is usually from bent valves, not floating them.
Cliffs: flat valves are for increasing CR when you can't get the right pistons...
junkyard racer
Sep 7, 2008 04:41 PM
PARADOX_sf
Mar 7, 2008 01:37 PM
WalkerGSR1
Jan 11, 2007 11:16 PM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
Smoothy
Sep 23, 2001 05:38 PM
