is 20psi achievable with this setup??
Old Dec 5, 2003 | 11:26 AM
ek9turbo's Avatar
Default is 20psi achievable with this setup??
here is the setup:
ls block, stock sleeves (block guard)
81.25 je pistons
9.1:1 compression
eagle rods
balanced crank
type r head, cams,
edlebroke intake manifold, port matched to head,
skunk2 springs,retainers and cam gears
msd 6al
drag turbo kit
550 injectors
s100 hondata
the turbo is a t3t4 ( .57 trim, .63 A/R)
tail wastegate 9psi spring
what do guys think about 20psi with this , assuming that injectors supply enough fuel
Old Dec 5, 2003 | 12:05 PM
TurboJesse
Guest
Posts: n/a
Default Re: is 20psi achievable with this setup?? (ek9turbo)
with larger injectors yes, doubt it with 550's
Old Dec 5, 2003 | 12:42 PM
System-7's Avatar
the anser is NO!. why. don't ask you won't like the answer
Old Dec 5, 2003 | 01:05 PM
g2turbo's Avatar
Default Re: (System-7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by System-7 &raquo;</TD></TR><TR><TD CLASS="quote">the anser is NO!. why. don't ask you won't like the answer</TD></TR></TABLE>
wow im sure he will appreciate all your help.
to answer your question.. yes its possible but i would say that you will need larger injectors to make that happen. At 20 psi on that turbo you should be close to 400 whp and that will most likely put the 550's at 100% duty cycle. But just go to the dyno and find out for yourself. you cant obviously just turn it to 20 and go. Tuning will be the key. HTH. CHRIS
Edit*
A guy locally here runs drag turbo kits on many of his setups and i know he has pushed a few of the cars to nearly 28 lbs. I dont know if the turbo is even efficient at that level but ... its been done alot. off course that was with some sort of engine management
Old Dec 5, 2003 | 01:11 PM
bretx0r's Avatar
yes. with the proper tuning but 20psi can mean a lot of things depending on how agressive the tune is. 550cc may not be enough
Old Dec 5, 2003 | 01:46 PM
ek9turbo's Avatar
still would like to know, that why i asked!!
thanks everyone for ur help
Old Dec 5, 2003 | 02:27 PM
Johnyquest's Avatar
Default Re: (ek9turbo)
On the drag website, http://www.dragturbokits.com , you will see that he states that the turbo is good to 25 psi and I beleive it was 450hp. Go look and see for yourself.. the psi number i'm positive of. If he's right, that's another story...
Old Dec 5, 2003 | 03:37 PM
Disco Stu's Avatar
Let me take a wild guess......Eagle rods?
That's not my personal opinion but it seems that a bunch of people here don't like the Eagles.
As for your question. 20 psi is a lot on 550s. I know of a guy running 720s on his 367 hp civic tuned by an AEM EMS, and while in boost (1 bar) it holds a perfect low to mid 11:1 AFR and he was maxing the injectors at an 86% duty cycle. That to me would say that 550s would run out of breath.
Modified by Disco Stu at 4:47 PM 12/5/2003
lakai_19
Oct 18, 2010 07:53 PM
hondaEg_808
Apr 23, 2010 06:49 AM
ebbshatch
Feb 22, 2006 03:36 PM
Bartman201
Oct 6, 2005 11:09 AM
ek9turbo
Dec 2, 2003 10:20 AM
