Two quick easy questions...
Old Dec 4, 2003 | 01:25 PM
Combustion Contraption's Avatar
Default Two quick easy questions...
Does anyone know what gauge wires honda uses throughout the engine harness? i need to lengthen my o2 sensor so i wanted to use the same gauge wire.
and the other question is: what is the normal temperature thermostat im supposed to use? i have a 180 degree one that looks like it will fit. would this be ok?
Old Dec 4, 2003 | 03:08 PM
ttt... anyone?
Old Dec 4, 2003 | 04:25 PM
cmon, someone answer this!
Old Dec 4, 2003 | 05:07 PM
Old Dec 4, 2003 | 06:05 PM
ARGH
Old Dec 4, 2003 | 10:49 PM
ttt again.
Old Dec 5, 2003 | 04:44 AM
JimBlake's Avatar
Default Re: (LsVtec92Hatch)
I suppose they would use different gagues on different circuits. Depends on the load.
180 is on the cold side but lots of people use that. I think stock is more like 89 C or 192 F.
Old Dec 5, 2003 | 02:03 PM
i need to know the thickness of the o2 wiring.
Old Dec 5, 2003 | 02:13 PM
2+2=5's Avatar
I am guessing 8
Old Dec 5, 2003 | 03:11 PM
Jimmy's Avatar
Global Moderator
Why are you extending it?
Old Dec 5, 2003 | 04:46 PM
jweller's Avatar
Default Re: (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">I am guessing 8
8 is huge compared to most of the wires in the harness that I've seen. it's closer to 16 or 18 just eyeing it up.
Old Dec 5, 2003 | 06:34 PM
someone told me it was 22. anyway, im extending it because im doing a swap and my o2 will now sit at the end of the header whereas now (vx model) it sits up near the cylinder head because of where my cat is placed.
Old Dec 6, 2003 | 01:44 AM
Mista Bone's Avatar
D Tranny Guru
why don't you go MEASURE instead of being a panty waste and bumping the thread to hell and back?????
Are you that LAZY?????????
Old Dec 6, 2003 | 11:46 AM
dfoxengr's Avatar
ur going to run a vx ecu on a swap? if not then you cant use the 5wire vx sensor and you need to get a 4wire and new ecu. PS. it doesnt really matter the guage as long as you get something close, i think i use like 16 or something maybe 18, but if its a little bigger WHO CARES.
Old Dec 6, 2003 | 07:34 PM
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">why don't you go MEASURE instead of being a panty waste and bumping the thread to hell and back?????
less worrying about me...
more shutting the **** up.
MATiC
Dec 7, 2006 07:55 PM
rasinhell
Audio / Security / Video
Aug 18, 2005 02:43 PM
chihuahuamanx
Feb 28, 2005 05:56 PM
AZNBIGPIMPN505
Jan 11, 2005 08:07 AM
hondaracing1
Nov 28, 2004 08:09 PM
