What gauge wire to extend o2 sensor?
Hey guys, I just figured i'd post in here since most of you guys would know more about wires and stuff. I'm trying to extend one of the plugs for an o2 sensor. I was just wondering what gauge wire i should use and do I use one of those tube thingys that you crimp down?
Use a 20 gauge wire:
http://www.radioshack.com/prod...8-565
You can also use 18 gauge but the stock size is 20 gauge. The reason you should use a small size is becasuse the o2 sensor gives off really really low volt. and if you use a thick wire it loss volt. and your cel will come on. Also if your going to us a a/f ratio gauge take it from me and tap the ecu wire and not the o2 sensor wire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch »</TD></TR><TR><TD CLASS="quote">would 22 gauge be alright???</TD></TR></TABLE>
It should be ok. 20-22 are small and shouldnt mess with the voltage comming from the o2 sensor!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">I used 18 gauge and it looked thicker than the stock o2 wiring. Still worked fine with no problems though.</TD></TR></TABLE>
18 gauge is ok but I dont recommend it because how much voltage comes from the sensor is very very little.
So now people:
To extend your o2 sensor use:
Butt conntecters:
http://www.radioshack.com/prod...-3108
18-22 aeg wire. But I recommend 20-22 awg:
http://www.radioshack.com/prod...-1218
Wire loom:
http://cableorganizer.com/wire-loom/colored.html
So now people:
Butt conntecters:
Wire loom:
screw the butt connectors solder your wires and use heatshrink.
You don't need a large gauge wire you not passing much current through the wire.
A larger wire shouldn't do anything to the voltage but it may shift the time the signal gets to the ECU. Larger wire will have more inductance and capacitance.
maddcrx
Honda S2000
Jun 26, 2008 03:55 PM
