h22a4 in 95 civic eg shifter problems
Old Dec 4, 2003 | 10:27 AM
gdrum's Avatar
Default h22a4 in 95 civic eg shifter problems
okay so sometimes when im at a stoplight or getn ready to go and i go to put it in 1st gear...it wont go into first....ill push clutch in and out.....then itll pop right in......and also 5th gear grinds sometimes when i go to put it in 5th......we just put a new tranny in it....are there adjustments and where how do i do them...
Old Dec 4, 2003 | 02:29 PM
meanEG's Avatar
Default Re: h22a4 in 95 civic eg shifter problems (gdrum)
make sure the cables arent binding up htere might be an adjustment on there. ill check the repair manual.
Old Dec 4, 2003 | 04:41 PM
gdrum's Avatar
Default Re: h22a4 in 95 civic eg shifter problems (meanEG)
okay yeah i htink it has to do with cables or adjustment in the shifter i just dont know where to start or look....
Old Dec 6, 2003 | 06:51 PM
xxxtodxxx's Avatar
just sounds like normal lude tranny problems. the 5th gear grinding is the notorious 5th gear grind. and the tranny is a piece of poop buy the way. lol. now you know what luders have to put up with.
Old Dec 6, 2003 | 08:36 PM
gdrum's Avatar
Default Re: (xxxtodxxx)
damn, i wonder if there is an adjustment or something
Old Dec 12, 2003 | 04:36 AM
ozzyman's Avatar
Default Re: (gdrum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum &raquo;</TD></TR><TR><TD CLASS="quote">damn, i wonder if there is an adjustment or something
Also would like to know.
Old Dec 12, 2003 | 06:53 AM
v4lu3s's Avatar
RTFM
usually i ihave seen that from teh shift cables not being able to move freely.
Old Dec 12, 2003 | 11:10 AM
Jason kiDD's Avatar
Default Re: (v4lu3s)
I never had shifter problems in my 3 years with this engine/tranny combo..
Check your fluid level..
Old Dec 12, 2003 | 02:17 PM
AMeg6's Avatar
i have a tranny forsale if u decide u need one
Old Dec 13, 2003 | 02:13 PM
fastwanabe's Avatar
Default Re: (AMeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMeg6 &raquo;</TD></TR><TR><TD CLASS="quote">i have a tranny forsale if u decide u need one</TD></TR></TABLE>how much? does it have LSD?
Old Dec 13, 2003 | 11:03 PM
jdmcivicferio's Avatar
First thing I would check is it sounds like you have a hydro problem for example, your clutch master cylinder or slave cylinder could be faulty and leaking and not holding enough pressure, for example by you saying you have to pump up the clutch to get it into gear is a hydro problem, or a leaking clutch flex line. Thats what I would check first.
b18b_eg94
Transmission & Drivetrain
Apr 23, 2009 12:32 AM
blankslat5
Nov 4, 2008 02:59 PM
CXtypeR
Jan 20, 2007 02:03 PM
gm3w12
Sep 27, 2006 09:08 PM
civproject14
13
Dec 8, 2004 02:27 PM
