The return of jcaudill as HokieITR! :-)
Old Sep 17, 2001 | 04:02 PM
HokieITR's Avatar
New User
Default The return of jcaudill as HokieITR! :-)
Hey all-
To those who remember me I'm pretty much hanging around in the ITR forum these days. I'm cruising in a 2k ITR, #55. I must say I finally understand what these babies are about, make no mistake Honda did a fine job.
But, I fear someday in my life turbo will return. So, I've started doing a little research for the heck of it. I've done a little math, and done some compressor map observations and have found that the T04E "54" is going to be my best match. Has anyone tried this, or knows who sells this? I just want to start getting a feeling for what's out there.
Give me a shout!
http://bam.vigor.net/typer/IMGS0045.JPG
Old Sep 17, 2001 | 06:36 PM
DragII's Avatar
Default Re: The return of jcaudill as HokieITR! :-) (HokieITR)
Welcome back man...I knew that VW wouldn't hold ya!
Old Sep 17, 2001 | 08:18 PM
Liltrix's Avatar
Call XS Engineering and speak to Tri pronounced "Tree" He will take care of U.
714-992-4133
Old Sep 18, 2001 | 02:36 PM
HokieITR's Avatar
New User
Default Re: The return of jcaudill as HokieITR! :-) (DragIIcivic)
Haha, how right you were! My parents took it so at least it's still in the family.
How's everyones cars doing?
Old Sep 18, 2001 | 02:38 PM
DragII's Avatar
I managed to kill off my engine..and I'm going to swap to the darkside, and add boost
Old Sep 18, 2001 | 02:48 PM
HokieITR's Avatar
New User
That puts a tear in my eye I'm happy to hear it!
Old Sep 18, 2001 | 06:54 PM
TurboInteg95's Avatar
the 54 looks like it should work pretty well. what size exhaust housing are you going to use? I would definitely go with a .63 but the exhaust wheel could be debated. I think either a stage 2 or stage 3.
Old Sep 19, 2001 | 03:09 AM
HokieITR's Avatar
New User
Default Re: The return of jcaudill as HokieITR! :-) (TurboInteg95)
You know I haven't figured that out yet. I know the calculations for the air flow to figure out the best turbo but I don't know how to pick the exhaust housing. Is there a mathematical way of figuring out the bext? Basically, I used Ray Hall's TurboCalc to say ok, 8600rpm, intercooled, 4 cylinder, running 8psi (I wanted that to be the sweet spot), and so I came out with like 22.1 for the airflow and I think it's 1.5 bar.
[Modified by HokieITR, 12:10 PM 9/19/2001]
Old Sep 19, 2001 | 12:52 PM
they're little calculator is pretty accurate. When I do my numbers I always come up with a little more air flow then them. I think they're using a low VE number because they're a bunch of redneck V8 guys with gay engines that are totally inefficient. I'm sure there is some math behind choosing exhaust housings but I dont know it. You'll definitely want to go with a .63 the question is stage 2 or stage 3 wheel. maybe someone else here can help. I'm thinking stage 3. Those damn Type R motors move so much air and make a lot of power.
digitalVinyl
Dec 7, 2006 10:08 AM
ZygSpeed
Aug 4, 2005 06:29 PM
JerseyMike
May 6, 2005 08:36 PM
Milhouse Van Houten
Jan 26, 2004 07:47 PM
