Damn Ticking at Idle, valve adj done many times, lma's fine...
Old Dec 3, 2003 | 09:29 PM
4gen's Avatar
Default Damn Ticking at Idle, valve adj done many times, lma's fine...
So, there's a ticking at idle, not all the time but just after idling for a min or so... valve adj has been done many times, along with checking of LMA's, but ticking persists. Any idea's???
Setup:
Stock H22A
CAI, Exh.
ACT clutch, CM fw
Valves set to - Int: 0.006 and Exh: 0.007
Old Dec 4, 2003 | 05:12 AM
4gen's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (4gen)
oh come one guys, whats the possible scenarios, searched and only found "valve adj. needs to be done" and "it's possible the LMA's aren't working properly, so get new ones"...
Old Dec 4, 2003 | 05:29 AM
Revi's Avatar
My car has been ticking at idle for as long as i can remmember. Even after a valve adjustment. I noticed after i installed the CAI the sound was more noticable, so maybe that has something to do with it.
Old Dec 4, 2003 | 05:30 AM
TurboSam's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (Revi-Ra)
injectors
Old Dec 4, 2003 | 07:38 AM
DW's Avatar
DW
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (Turbo Sam)
not to jack your thread but what are the LMAs and what exactly do they do because i kinda have the same problem and i have done a valve adjustment a few times but the noise is still there. how do you check them?
THanks,
David
Old Dec 4, 2003 | 07:45 AM
lOOkatme's Avatar
my valves are loud at idle when the car is cold. after it warms up the ticking goes away. I just did a valve adjustment....so it ticks regardless of valve clearence when the engine is cold.
Old Dec 4, 2003 | 07:55 AM
SKDRCR's Avatar
Default Re: (lOOkatme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lOOkatme &raquo;</TD></TR><TR><TD CLASS="quote">my valves are loud at idle when the car is cold. after it warms up the ticking goes away. I just did a valve adjustment....so it ticks regardless of valve clearence when the engine is cold.</TD></TR></TABLE>
W3rd, welcome to the world of preludes
Old Dec 4, 2003 | 10:20 AM
luder94-ChrisA's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (DW)
LMA = Lost Motion Assembly
They are found only on VTEC hondas like the H22 engine.
Old Dec 4, 2003 | 04:55 PM
4gen's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (luder94si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder94si &raquo;</TD></TR><TR><TD CLASS="quote">LMA = Lost Motion Assembly
They are found only on VTEC hondas like the H22 engine.</TD></TR></TABLE>
They're purpose is to prevent the Vtec Rocker arm from wobbling around when the engine is not in Vtec mode. The just have a spring with a head that pushes up on the vtec lobe while not it vtec.
Old Dec 4, 2003 | 05:03 PM
4gen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">injectors </TD></TR></TABLE>Can you tell me why the injectors, I know you talked about it in another thread but can't remember the title. Thanks.
Old Dec 4, 2003 | 05:06 PM
TurboSam's Avatar
basically, when your injectors get clogged, or something breaks in them, they tick loudly. you injectors click anyways, they just arent very loud.
think of it this way, when u press the lock and unlock button on your door, you can hear the actuator, and whenu try to lock it after its locked, or unlock it after its unlocked, the actuator itself makes a louder noise.
fuel injectors are nothing more than small acutators, and they open and close at the rate of miliseconds, so, when one is stuck open or closed (typically they hang open though b/c trash can hang them u as it passes through) it will make a very rapid clicking that sound very very similar to valve tick
Old Dec 4, 2003 | 06:15 PM
93ludeSi's Avatar
also, what weight oil are you running, when my motor was real tired i was running 15-40 cause it would burn it faster then i could dump it in, the valves were def louder at start up with the heavier oil
Old Dec 5, 2003 | 08:54 AM
Revi's Avatar
Would running on empty alot clog your injectors? I tend to wait till the last minute to get gas and i know all that dirt and deposit at the bottom of the tank could get sucked in. But wouldnt it affect the fuel pump or filter first? The fuel is filtered before i gets to the injectors, right?
Old Dec 5, 2003 | 09:11 AM
TurboSam's Avatar
yes, it is filtered, but occasionally, small deposits can still pas though. the end of the injectors where the fuel passes through is about the size of a small sewing needle, so even a speck of dust could hang it up
Old Dec 5, 2003 | 05:15 PM
4gen's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (93ludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">also, what weight oil are you running, when my motor was real tired i was running 15-40 cause it would burn it faster then i could dump it in, the valves were def louder at start up with the heavier oil</TD></TR></TABLE>
Im running 10-30, oem specification, it's more of a daily driver than anything.
Modified by 4gen at 10:34 AM 12/7/2003
Old Dec 5, 2003 | 05:33 PM
4gen's Avatar
So what would help this out, possibly replacing the fuel filter, getting the injectors flowed and tested?
Old Dec 6, 2003 | 01:57 PM
del_parker's Avatar
so is it still ticking once the engine is warmed up?
i know mine ticks until the engine is warm.
Old Dec 6, 2003 | 02:43 PM
4gen's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (del_parker)
No mine doesnt, it ticks at idle no matter the engine temp. It's an inconsistent ticking, only does for a little while, stops...then a couple times, stops for a minute, does it for 5 min then stops for 10 seconds. It's unpredictable and there is no pattern to follow.
Old Dec 6, 2003 | 10:05 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gen &raquo;</TD></TR><TR><TD CLASS="quote">
Im running 10-40, oem specification, it's more of a daily driver than anything.</TD></TR></TABLE>
actually oem spec is 10w30
Old Dec 7, 2003 | 09:35 AM
4gen's Avatar
Default Re: Damn Ticking at Idle, valve adj done many times, lma's fine... (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
actually oem spec is 10w30 </TD></TR></TABLE>
edit: Im running 10-30
DaYZeD.1
Apr 19, 2008 03:07 PM
wullie_vtec
Apr 18, 2006 07:04 PM
redex94
Mar 22, 2005 10:28 AM
jdmBOMEXsi
25
Mar 16, 2005 11:52 PM
Mike1486
Sep 23, 2004 06:20 AM
