Thinner OEM Head Gasket
Old Dec 3, 2003 | 08:37 PM
All-Motor H22A's Avatar
Default Thinner OEM Head Gasket
Hello Everyone,
I'm about to change my valvetrain and need a new head gasket. I have a stock JDM block w/ 10.6:1 Compression Ratio.
If I use a stock OEM Headgasket and take out the middle layer, does anyone know what my compression might be?
Old Dec 3, 2003 | 09:04 PM
Crate's Avatar
guessing about 10.8
Old Dec 4, 2003 | 12:43 PM
Default Re: (Crate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crate &raquo;</TD></TR><TR><TD CLASS="quote">guessing about 10.8</TD></TR></TABLE>
I'm hoping that to be true. Should be good for a few WHPs right?
Old Dec 4, 2003 | 01:32 PM
94vtecmn's Avatar
Default Re: (All-Motor H22A)
Stock JDM blocks are 11.0:1.
Stock USDM are 10.6:1.
Correct me if I'm wrong.
Old Dec 4, 2003 | 01:38 PM
caLiH22A's Avatar
Default Re: (94vtecmn)
Correction...
JDM blocks have 10.6:1 compression while USDM blocks have 10:1 compression. The JDM Type-S motor has the 11:1 compression along with some European motors aswell.
Old Dec 4, 2003 | 01:45 PM
explosive's Avatar
Can't you shave more than that? Or is there another head gasket that you could buy to get a higher compression?
Old Dec 4, 2003 | 05:54 PM
Default Re: (explosive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explosive &raquo;</TD></TR><TR><TD CLASS="quote">Can't you shave more than that? Or is there another head gasket that you could buy to get a higher compression?</TD></TR></TABLE>
Well, bascially, they have aftermarket head gaskets that are thinner to rasie it up pretty good amount.
However, I don't want to spend that much. Some people use an OEM head gasket and take one layer out. It's a 3 layer head gasket. Some people supposedly take out two layers, but I don't know if I can trust that.
ProjectBB6
Mar 13, 2008 09:24 AM
RICE POLICE SIP
Apr 16, 2006 03:20 PM
xyzalvarez
31
Sep 5, 2005 09:54 AM
HondaHead211
Aug 23, 2005 10:56 AM
prdtr15
Sep 25, 2003 03:45 PM
