for tech heads, is my clutch gone?
Old Dec 3, 2003 | 07:30 PM
HatchBox's Avatar
Skoobie no more...
Default for tech heads, is my clutch gone?
well i originally made a post about how i thought my axle/tranny was bad but on further investigation mackymcg and myself noticed a stange noise coming from the clutch area of the tranny like a metal on metal clanking.
here is a sound file, sorry about the quality, but this used to be a 34263k avi file that my friend reencoded
http://www.we-todd-did-racing....D.jpg
Old Dec 3, 2003 | 07:40 PM
PhatOptimo's Avatar
Default Re: for tech heads, is my clutch gone? (ind3ciso)
How old is the clutch? How many miles? Does it engauge properly? Sounds like a bolt is loose in there and its getiing banged around. You can remove the dust shild and see if there is any froeign object inside. Its hard to tell what the problem is though.
Old Dec 3, 2003 | 07:51 PM
HatchBox's Avatar
Skoobie no more...
Default Re: for tech heads, is my clutch gone? (PhatOptimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">How old is the clutch? How many miles? Does it engauge properly? Sounds like a bolt is loose in there and its getiing banged around. You can remove the dust shild and see if there is any froeign object inside. Its hard to tell what the problem is though. </TD></TR></TABLE>
thats the thing...brand new action clutch
just got the car moving so like 25-35 miles
engauges fine.
Old Dec 3, 2003 | 07:56 PM
PhatOptimo's Avatar
Hummmm... Sounds like something is banging around in there. Did you install the clutch? Torque all the bolts in the propper sequence? I'd pull the dust shield and crank it up again and see if you can maybe pin point the odd noise. I hope its nothing major.
Old Dec 4, 2003 | 04:41 AM
HatchBox's Avatar
Skoobie no more...
pcorad
Aug 10, 2007 09:57 AM
Chaser4dr
37
Jul 25, 2007 11:59 AM
JoNNiE
Dec 2, 2004 12:06 PM
SOHC_Brian
Aug 23, 2004 09:58 AM
ekdriven
May 18, 2004 11:55 AM
