leaking vacume
hey guys
i just hecked my car out cause i had the uuuuuuummmmmmmmpppppppaaaaaaaing from iac i thought it was a rad leak but everything was fine. so i checked for a vacume leak and i found out that it's my wastegate so i opened it up and the diaphram looks fine so i sealed it up again and still the same problem. anyways i checked more and the leak is from the bottom of the wastegate. do you guys know where i could order a rebuild kit for it it's a deltagate 35mm. if any of you guys on here could help me out it would be great
