Q's about mini-me
Old Dec 3, 2003 | 04:18 PM
d15b7racer's Avatar
Default Q's about mini-me
first off let me start by saying that i already used the search and came up with so many different answers i'm going to try ask again. Dont flame.
Heres my question....i have a d15b7 and wanted to put on the z6 head. I wanna run the lowest possible compression i can so which head gasket do i use? Second question is....which timing belt do i use? I've heard VX because its still the 1.5 block but also heard z6 because the amount of teeth. Anyone know for sure? Last question.....which water pump would i use? b7 or z6? or r they the same? Any help is appreciate. Have a nice day
Old Dec 3, 2003 | 04:21 PM
Kendall's Avatar
If you want to run the lowest compression possible, go ahead and get a good aftermarket head gasket that is designed to do this.
Old Dec 3, 2003 | 07:08 PM
MrTodd's Avatar
Default Re: (dc231)
Z6 HG is the thickest D-series OEM metal headgasket out there. Use the water pump that's associated with the block (b7). Use the timing belt that's associated with the head (z6).
Old Dec 3, 2003 | 10:10 PM
d15b7racer's Avatar
Default Re: (MrTodd)
so the thicker the gasket the lower the compression? i did not know this. is there anything thicker than the z6 oem?
Old Dec 4, 2003 | 05:09 AM
BauleyCivic's Avatar
Risky Business
Default Re: Q's about mini-me (d15b7racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b7racer &raquo;</TD></TR><TR><TD CLASS="quote">first off let me start by saying that i already used the search </TD></TR></TABLE>
Obviously you didnt...
https://honda-tech.com/zerothread?id=554053
Z6 timing belt
water pump is for block (b7)
for lowest compression use b7 head gasket
Have a nice day
Old Dec 7, 2003 | 03:42 AM
d15b7racer's Avatar
Default Re: Q's about mini-me (BauleyCivic)
no i did search...maybe the waterpump was there but i bookmarked that link awhile ago. It doesnt say anything about the lowest compression...you only mention the Y8=higher and for the timing belt there seems to be a lot of opinions on this. other than that i appreciate ur help.
Old Dec 7, 2003 | 08:01 AM
Kendall's Avatar
Check with aftermarket gasket companies like Mr. Gasket. The should be able to supply you with a gasket thicker than any stock gasket.
Old Dec 7, 2003 | 11:35 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b7racer &raquo;</TD></TR><TR><TD CLASS="quote"> It doesnt say anything about the lowest compression... </TD></TR></TABLE>
why do you want to lower compression?
Old Dec 10, 2003 | 05:28 AM
d15b7racer's Avatar
i'm already turboed thats why
Joey Mitchell
13
Apr 6, 2019 09:05 PM
Novtec4u
Jun 29, 2009 06:42 PM
EFstyle
Nov 5, 2008 05:48 PM
gotboosthatch
Feb 15, 2008 10:21 PM
