Which Transmission Fluid?
Old Dec 3, 2003 | 05:51 AM
RacingLude's Avatar
Default Which Transmission Fluid?
I have a Accord Type R Transmission with the helical LSD and was wondering what you guys think I should use for fluid. I'm currently using Redline MTL.
Thanks
Old Dec 3, 2003 | 10:45 AM
nuc79's Avatar
Default Re: Which Transmission Fluid? (RacingLude)
GM Synchromesh (friction mod. type).
Old Dec 3, 2003 | 10:54 AM
bad-monkey's Avatar
OEM Honda.
Old Dec 3, 2003 | 12:43 PM
RacingLude's Avatar
Thanks for the replies.
So having LSD doesn't change the type of fluid you use?
Old Dec 3, 2003 | 12:47 PM
KW2000's Avatar
Default Re: (RacingLude)
OEM Honda
Old Dec 3, 2003 | 01:25 PM
se93's Avatar
Hi Tony:
How's that ATR tranny doing? Use genuine honda MTF. That is what i use on my ATR tranny.
Old Dec 3, 2003 | 01:33 PM
RacingLude's Avatar
Default Re: (se93)
Hi Mark. It's doing great. Although I need to find out whats up with car. It's pulling to the left under accleration and then straight under coasting. There popping and clanging sounds coming from under the car. It's at the shop right now, I should know something in a couple days. Hopefully just a axle or bushing.
Maybe I should switch back to OEM. The few things I've heard about Redline kind of scares me.
Old Dec 3, 2003 | 01:54 PM
HKSpowers's Avatar
I just bought a liter of syncromesh, I cant wait to try it out!
Old Dec 3, 2003 | 02:52 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacingLude &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies.
So having LSD doesn't change the type of fluid you use? </TD></TR></TABLE>
depends. gear type LSD's, no.
Clutch type LSD's need to have a special tranny fluid used.
Old Dec 3, 2003 | 10:07 PM
jdmcivicferio's Avatar
Default Re: (bad-monkey)
OEM honda fluid, Honda's hate synthetics..... OEM or learn the hard way..
Old Dec 4, 2003 | 03:54 AM
InitialJRift's Avatar
* B A N N E D *
Default Re: (jdmcivicferio)
OEM Honda, I wouldn't reccomend anything else..
Old Dec 4, 2003 | 05:35 AM
Sephro's Avatar
Default Re: (InitialJRift)
Synchromesh it's far better than Honda MTF.
They sell it at AutoZones Penzoil Synchromesh MTF it's around $5 Qt
or you can buy it with the GM Synchromesh MTF label for $10 Qt.
I promise you won't be disappointed.
Old Dec 4, 2003 | 06:37 AM
BA5's Avatar
BA5
Default Re: (Sephro)
OEM Honda
'cause it works'
Old Dec 4, 2003 | 12:41 PM
dankbudz11357's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">Synchromesh it's far better than Honda MTF.
I promise you won't be disappointed. </TD></TR></TABLE>
need to try the synchromesh. grinds going into 5th, would be a quick fix until i do my tranny rebuild or source a type-s tranny
Old Dec 4, 2003 | 12:45 PM
racekar's Avatar
gm synchromesh is way better than oem and redline i tried both and i disagree oem is not better than gm synchromesh. i havent tried the gm friction modified type just the regular synchromesh. I did notice after a couple of road racing events its doesn feel as smooth but i still dont grind like i used to with redline and oem
Rene1123
Jun 23, 2010 09:59 AM
jdm inc
May 20, 2010 11:21 AM
L8APX
Apr 3, 2008 03:42 PM
97turboteg
Sep 7, 2006 10:30 PM
garyc17
Jul 27, 2006 11:04 AM
