Any one have an extra knock sensor connector plug?
Old Dec 2, 2003 | 09:19 PM
(JON)'s Avatar
Default Any one have an extra knock sensor connector plug?
i bought a motor with no engine harness, and now this is the only connector plug for th knock sensor. if it matters its obd1 motor and engine harness. any help would be appreciated. thank you
Old Dec 3, 2003 | 04:23 AM
VTECVillain's Avatar
Default Re: Any one have an extra knock sensor connector plug? (DaStyle)
Any standard 2 prong plug from any OBD0, OBD1 or OBD2 engine harness will work. It's the same plug used for the IAT, VTEC pressure, most IACV's, etc. The knock sensor only has 1 lead going to it also, should be the top insert when plugged in but just match it to the sensor to be safe.
Old Dec 3, 2003 | 06:05 AM
(JON)'s Avatar
thanks for the info
jdm_sai
Jul 18, 2010 06:05 AM
Boarderx192
Aug 13, 2005 12:10 PM
blackdude
Mar 29, 2004 08:26 PM
