Small Garrett gt2252 for b1ã2?
Old Dec 2, 2003 | 03:09 PM
crxdelsol's Avatar
Default Small Garrett gt2252 for b16a2?
Hello to all, I am of Spain and I am mounting I disturb to b16a2, my question is that it seems to them the turbine that I have bought, ar of escape is 47 and the one of compressing is ar 51, is too small, to be thankful your aid, a greeting
Old Dec 2, 2003 | 03:12 PM
SiRkid's Avatar
Default Re: Small Garrett gt2252 for b1ã2? (crxdelsol)
i think i got that..
that is a pretty small turbo but for a b16... im thinking it may be ok.
try it out. if it sucks, sell the turbo and get something bigger.
Old Dec 2, 2003 | 03:25 PM
RenoRacing's Avatar
Default Re: Small Garrett gt2252 for b1ã2? (SiRkid)
That is small but nothing that wont perform for up to 250+hp and 10-14 psi of boost. It's bigger than a stock wrx turbo and I've seen those used several times on my friends cars(b16, b20) with great results and 15psi.
Old Dec 2, 2003 | 03:33 PM
crxdelsol's Avatar
Default Re: Small Garrett gt2252 for b1ã2? (RenoRacing)
My idea is on 10psi or 200/210hp, then east I disturb is worth to me? subira well of revolutions to the red line? thanks to help me
Modified by crxdelsol at 12:52 AM 12/3/2003
Old Dec 2, 2003 | 03:37 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdelsol &raquo;</TD></TR><TR><TD CLASS="quote">My idea is on 10psi or 200/10hp, then east I disturb is worth to me? subira well of revolutions to the red line? thanks to help me </TD></TR></TABLE>
HUH?
Old Dec 2, 2003 | 03:40 PM
crxdelsol's Avatar
Default Re: Small Garrett gt2252 for b1ã2? (mattssi)
I feel, I do not speak it or ingles very, my idea is not to happen of 10 psi, and my question is if this I disturb sera able to raise or the red zone
Old Dec 2, 2003 | 05:04 PM
B18EG6's Avatar
Default Re: Small Garrett gt2252 for b1à£2? (c
Hablo espanol un poco.... puedo traduzca quiza?
Old Dec 2, 2003 | 05:44 PM
Cramerox's Avatar
i think he is wondering if the turbo is good enough to get him up to redline.
I think the turbo will loose breath before it gets up there.
Old Dec 2, 2003 | 08:08 PM
SiRkid's Avatar
Default Re: Small Garrett gt2252 for b16a2? (crxdelsol)
.47 ex and .51 comp a/r's..
i think it might hold on up top!
i say your good to go!
Old Dec 3, 2003 | 04:39 AM
crxdelsol's Avatar
Default Re: Small Garrett gt2252 for b1àƒÃÃ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">i think he is wondering if the turbo is good enough to get him up to redline.
I think the turbo will loose breath before it gets up there.</TD></TR></TABLE>
ok, that is my question, it can be worth to me I disturb? or he is very small? I can arrive with the a 8000rpm? single I want to reach 7 psi, thanks for the answers
Old Dec 3, 2003 | 06:48 AM
HXMan's Avatar
So you want to make 200-210whp with 10psi. You should be able to do that.
What do you mean by "single I want to reach 7psi?
Old Dec 3, 2003 | 07:07 AM
Charlie Moua's Avatar
from the looks of that turbo it looks perfectly fine for the b16. it will yeild fast spool with dent top end. The boost will not feel like a t3t4 reaching full boost but it will pull nicely all the way to redline of 8k. The b16 is a weird motor because it's only a 1.6 but it can dish out lot of air in the upper rpms so to find a turbo that gets good spool time yet no scrafice in topend power is going to be tricky.
try that turbo out. From the looks of it i think i has a t25 jdm flang so you should be able to use a greddy manifold. I personaly would go with the t28 .86a/r !!!
I think that turbo is slightly bigger than the 15G. IM "HybridEF2" he has a 15G in his b16 ef with hondata and at 10psi he makes 210whp with about 165tq on that little blower he gets full spool of 10psi at 3500rpms (which is not bad at all) his power does slightly drop or platue off at about 7200rpms to redline though.
if he had a t3t4 at 10psi he would get full boost at more like 4600rpms and make about 270whp and 190tq. so you just have to pick what you want as in power band you want.
HTH
Old Dec 3, 2003 | 07:12 AM
Johnyquest's Avatar
I think he is trying to say he want's to reach 7psi in first gear. I don't think you'll have a problem with that. The other post, it seemed as though he was trying to ask if it will run out of breath at redline, or if he will be able to RAISE the redline.
I think that turbo will be a nice match with your b16. It will make 10psi, no doubt, I'm pretty sure it will hold it to redline and beyond, and you will make almost 300hp if you max it out, without a problem.
Go for it, you will have fun!
Old Dec 3, 2003 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">I think he is trying to say he want's to reach 7psi in first gear. I don't think you'll have a problem with that. The other post, it seemed as though he was trying to ask if it will run out of breath at redline, or if he will be able to RAISE the redline.
Go for it, you will have fun! </TD></TR></TABLE>
that turbo will not make 300whp on a b16 unless you have higher compression, really good tuning & running like 16psi or more! ........ also that is if that internal wg can hold 16psi steadly w/out spiking.
and WTF would you want to reach boost in 1st gear? hell if i could i would want close to no boost in 1st gear cause it's soo damn quick = too much power= too much wheel spin= slower times=more tirewear ect? hahah lol
Old Dec 3, 2003 | 08:31 AM
SiRkid's Avatar
I hit full boost (6-10 psi)with my gt30 .82 ex a/r in 1st gear! ball bearing ownz.
that thing will hit full boost at like 3000 rpm ..itll be crazy i think.
mayfly
Feb 12, 2010 07:49 AM
ProjectBoosted
Northwest (Sales)
Feb 5, 2009 10:21 AM
civichatch2307
Aug 12, 2007 05:42 AM
Ef-er
Jul 1, 2004 02:46 PM
1996GsrVtec
Aug 21, 2002 07:49 PM
