OT: Overheating problem with my beater
I know its not really ITR related, other than the fact I now have to drive my R daily which I hate doing, especially since it was SNOWING today
Anyway I figure it could be good problem determination for everyone in general so Im posting it here.
Basically what it comes down to is my EG hatch is overheating, in a very serious way. It recently got a new radiator and thermostat, and it ran like a champ. Now suddenly this problem. Heres the symptoms:
- Temp gauge way past "H" lol
- Coolant spilling/spewing/exiting/spitting/squirting out of overflow can
- Upper radiator hose WAS "bulging" somewhat, then went back to normal
- while engine running, upper radiator hose kinda soft, almost like no pressure inside.
- the car does burn up coolant (I think the head gasket is going), and I recently added some and drove fine afterwards.
Im guessing the first things to check would be pressure in the system. But I dont have a tester. Since I know the radiator and thermo are new, Im thinking water pump which has probably never been replaced (130K). Probably a good time to change the timing belt as well.
What do you guys think?
Anyway I figure it could be good problem determination for everyone in general so Im posting it here. Basically what it comes down to is my EG hatch is overheating, in a very serious way. It recently got a new radiator and thermostat, and it ran like a champ. Now suddenly this problem. Heres the symptoms:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">It recently got a new radiator and thermostat</TD></TR></TABLE>
How recently? Possibly an air pocket in the system?
I dont recall if the fan was coming on or not. Is there a way to force it to turn on? Or do I just have to leave the car running and wait to see if it comes on. If it doesnt come on, what does that indicate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
How recently? Possibly an air pocket in the system?</TD></TR></TABLE>
Recent as in the past couple months so I dont think it was that, unless a pocket was in there after I added some coolant. But it was running fine after that as well.
if it does not come on you can over heat. yes you can have the fan on 24 7 if you pull the fuse and jump a wire. if the fan does not come on then your switch is bad
cbr_ryder
Classic Hondas
16
Jul 28, 2023 07:13 AM
