Why Is Low Compression Bad For Beefy Cams?
Old Dec 2, 2003 | 12:35 PM
lazy bum shaughn's Avatar
Default Why Is Low Compression Bad For Beefy Cams?
I don't understand why you would sometimes lose power instead of gain.
Old Dec 2, 2003 | 01:40 PM
dfoxengr's Avatar
Default Re: Why Is Low Compression Bad For Beefy Cams? (lazy bum shaughn)
not enough pressure in the cylinders
Old Dec 2, 2003 | 02:06 PM
spender1326's Avatar
Big cams usually = duration = overlap (both valves open) = lower dynamic (not static) CR (which even lower than b18b1's 9.2 sometimes); goto team integra.net site for an article that tells you how to calculate dynamic CR from cam profiles.
Old Dec 2, 2003 | 03:44 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Why Is Low Compression Bad For Beefy Cams? (spender1326)
Think about it this way:
A bigger cam allows more air and fuel to enter the combustion chamber pre-compression. Your car makes all its power based on getting large quantities of air and fuel into the cylinders, compressing said gasses, and evacuating the spent remainder in an efficient fashion. Lowering your compression doesn't allow all the extra air and fuel that your cam is allowing to be compressed to its fullest potential, therefore you're not gaining as much power.
Higher compression = more power. Period.
integra123
May 10, 2006 01:05 PM
precisionelite
Jan 11, 2006 11:06 AM
Modifiedinteg
Oct 25, 2003 03:10 PM
HX_Guy
Aug 22, 2001 02:00 PM
