LS cam gears...
Old Sep 17, 2001 | 12:06 AM
X2BOARD's Avatar
Default LS cam gears...
Getting some work done (maintenance) and I am thinking about putting a set of cam gears on an internally stock LS (cutting valve cover too)
With stock cams, would this be worth the fundage ? $180-$200 for Skunk2, or even Hayame (good deal down here) parts...
Would they be good for any Hp if tuned right ? Or should I put my $$ elsewhere ? Headers maybe....?
Old Sep 17, 2001 | 06:19 AM
eg6ajk's Avatar
Default Re: LS cam gears... (X2BOARD)
ligthten your stock flywheel to about 12lbs (about $120-150 for balancing, shaving, and resurfacing) or get a 7.5lbs Fidanza or CM or Mueller ($300), and you be happy,,,,get a K&N drop in filter unless you go with AEM cold air intake, next would be a less back prssure good free flowing muffler or header as in JDM ITR 4-2-1 ITR or JDM 4-1 ITR....
Old Sep 17, 2001 | 10:43 AM
maxxdout's Avatar
Default Re: LS cam gears... (eg6ajk)
join the club, i have been trying to do some research on the benifits of a mild cam in the LS, such as a crower 402. However i am unsure of the benifits of tuning the stock cams, as far as i know the LS is pretty well optiamized. Remeber that in our LS engines to build power at Higher RPM levels is somewhat difficutl simply because of the nature of the engine itself. It has a stronger mid range as opposed to a stronger high end.
if you are curious about the cam possibilities though check out :
https://honda-tech.com/zerothread?id=68156
might be of some help
Old Sep 17, 2001 | 11:20 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: LS cam gears... (maxxdout)
What you said is very true about the power in the LS. However, I have the Crower 402's in my 97 LS and there is quite a difference. I can pull on GSR's with mediocre drivers.
I believe with cams, it's wise to get an FPR and cam gears to balance everything out and tune out the most power. Gears on a stock cam won't yield much power, if any. Keep in mind that cam gears really don't give power, they move the powerband around giving you more power in certain rpm ranges as opposed to others. Someone correct me if I'm wrong, but I'm sure that's correct.
Old Sep 18, 2001 | 03:06 PM
maxxdout's Avatar
Default Re: LS cam gears... (shamoo)
no, as far as i konw you are right on with the cam gears. But no being able to speak from personal experence i cant say for sure. How did you like the 402s you installed? What else is yoru set up?
Old Sep 19, 2001 | 04:22 AM
95SiR's Avatar
Crower 402 cams for the LS is weaksauce.
i have the 403s and i wish i have gotten at least the 404's. my 403s idle exactly like stock, pulls hard from about 5k to redline but not hard enough. for mild cams, the 403s are definitely MILD to the most literal sense.
and cam gears definitely help on cams and other mods. just by adjusting the settings on my gears after getting it dynoed for "peak performance" as they claimed, i shaved off a full 1.0 sec off my 1/4mile e.t.
Old Sep 19, 2001 | 05:53 AM
maxxdout's Avatar
Default Re: LS cam gears... (95SiR)
so you would recomend the 403's? they 402's not worth it?
punkracer
Aug 3, 2005 07:12 PM
boosted hybrid
Dec 19, 2001 11:06 AM
maxxdout
Aug 27, 2001 10:09 PM
