Anyone running Crower Valvetrain in there D series?
Old Dec 1, 2003 | 08:10 PM
hatchback19's Avatar
Default Anyone running Crower Valvetrain in there D series?
I'll be investing quite a bit of money into a new valvetrain for my little built D but not sure who to go with. Is anyone running there springs/retainers in there D series? I was also looking at there Stage 3 cam, I'll be using Hondata so the ECU modification isn't a problem. It's still will be street driven so im sure if I sould just stick with stage 2. Anyways any help would be appreciated, thanks,
Matt
Old Dec 1, 2003 | 08:33 PM
94dxt's Avatar
Default Re: Anyone running Crower Valvetrain in there D series? (hatchback19)
I'm running Crower single valve springs and retainers, but you don't really need them for a boost application unless you want to rap out to 9k rpm or something. I just got a killer deal on them so I went for it. Also the z6 or y8 cam works just fine if not great I wouldn't waste the money on an aftermarket cam for F1
Old Dec 1, 2003 | 08:51 PM
I'm going to be running a pretty decent size turbo, it shouldnt have any problems making power to 8500 which is about as far as I want to go. What are you reving out at with just the springs and retainers? Thanks for the information,
Matt
Old Dec 1, 2003 | 10:34 PM
94dxt's Avatar
Default Re: (hatchback19)
7200(factory rev. limiter)
Old Dec 2, 2003 | 12:57 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (94dxt)
i plan on getting the stage 2 cam with the spring and retainer kit , ive herd good things about it
Old Dec 2, 2003 | 07:49 AM
norcalcrx's Avatar
We run a full ferrea valvetrain on our y8. Dual springs, .5 oversize nitrate coated valves and ti retainers.
Old Dec 2, 2003 | 07:51 AM
97Civic-R's Avatar
Default Re: (94dxt)
6800
Old Dec 3, 2003 | 02:59 PM
Thanks for the input guys, anyone else?
Old Dec 3, 2003 | 04:31 PM
Snail Tuning's Avatar
sorry not trying to thread jack. what if your ganna push over 10psi would a cam be benifical? i mean im ganna be running a fully build bottom with sleeves.
thanks
Old Dec 3, 2003 | 05:52 PM
Distorted's Avatar
Default Re: (bmcc72)
A cam would be beneficial, but its hard to say how much so, at most boost levels. What you want is a turbo grind with maximum duration. Dont worry about getting any extra lift. You can find excellent regrind companies that will do the work for $150.
TonacoJDM
10
Oct 5, 2013 07:09 AM
01_CivicEM2
Honda Civic (2001 - 2005)
13
Mar 10, 2010 08:10 PM
93formula
May 1, 2005 09:57 AM
TypeR0207
Feb 11, 2005 03:55 AM
Superdragr45
Jan 25, 2005 07:52 AM
