b16 clutch presure plate, and flywheel into 18c1??
Old Dec 1, 2003 | 07:33 PM
TurboBumblBee's Avatar
Default b16 clutch presure plate, and flywheel into 18c1??
thats right can i use a clutch, presure plate, and flywheel out of a b16 in my b18c1 thanks?
Old Dec 1, 2003 | 07:50 PM
TeamNextGenChris's Avatar
Default Re: b16 clutch presure plate, and flywheel into 18c1?? (Hybrid95CivicEX)
as long as it's hydro tranny to hydro tranny,or cable to cable.
chris
Old Dec 2, 2003 | 04:51 PM
salbaje's Avatar
yes what he said as long as its from a Hydro
Old Dec 2, 2003 | 04:55 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: b16 clutch presure plate, and flywheel into 18c1?? (salbaje)
quit throwing around false information.
Have you ever tried putting a clutch from a cable tranny??? Probably not...
I have put ITR clutches in a CRX with B16 and a 90 Integra with original engine before....SOME can be interchangable...depends on the tranny in question
Old Dec 2, 2003 | 04:57 PM
chad's Avatar
Moderator
Default Re: b16 clutch presure plate, and flywheel into 18c1?? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">quit throwing around false information.
I have put ITR clutches in a CRX with B16 and a 90 Integra with original engine before....SOME can be interchangable...depends on the tranny in question</TD></TR></TABLE>
correct but 98% of the time a hydro clutch will not work with a cable tranny....
especially when you go ordering one for a hydro tranny i will bet it won't work...but when you have them laying around and can figure out what will work yes then it will work!
Old Dec 2, 2003 | 05:13 PM
what tranny code do i need to look for in order to know forsure that it will work on my b18c1?? cause my friend did say something about an integra part in the clutch setup! i hope it works, its free and all i need to do is drop the motor and tranny and take it off..
Old Dec 2, 2003 | 06:55 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">
what tranny code do i need to look for in order to know forsure that it will work on my b18c1?? cause my friend did say something about an integra part in the clutch setup! i hope it works, its free and all i need to do is drop the motor and tranny and take it off..</TD></TR></TABLE>
for you, just use any B series clutch from a 94 on up...as it will be hydro.
When we're talking swapping from hydro and cable....then there's different situations...I was trying to get the replies straightened out...
Old Dec 2, 2003 | 08:11 PM
zer0.'s Avatar
the cable trannies from 92-93 integras are the same as 94+ hydrolic b series trannies.
all b series hydrolic trannies are the same,the clutch,flywheel,and clutch are interchangable.
Old Dec 2, 2003 | 09:09 PM
Default Re: (zer0_2_6ixty)
okay,lets get this straight.....
all B-series flywheels are interchangable.they work with hydro or cable tranny.
cable trannies use a specific throwout bearing,hydro trannies use a different one.
most manufacturers list different clutchs for 90-91,92-93 and 94+ B-series motors;some list the same kit for 92+,and a different one for 90-91.
they ALL have 220mm discs,with 24 spline input shafts.so i'm not sure what the actual difference is-it's not like d-series setups where you have different diameter discs and different input spline counts.
seems the clutches should all be interchangable,can anybody elaborate on this?
chris
jdmstyler
Apr 21, 2007 11:54 PM
jpangeles
Sep 22, 2006 01:47 AM
blk007
Jul 13, 2005 04:21 AM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
TurboBumblBee
Dec 2, 2003 01:52 PM
