question about clutch and flywheel between cable and hydro tranny
Can a clutch and flywheel from a b16 cable tranny work on that same motor with a hydro tranny? i need to know so i could know whether to purchase the clutch or not. Thanks in advance
Re: question about clutch and flywheel between cable and hydro tranny (K SERIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K SERIES »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=675666
https://honda-tech.com/zerothread?id=1262838
after reading that i guess the answer is no i'm confused you added a second link stating that the hydro clutch could work in the cable tranny no problem but the first link says it's incompatible? is it one way only, meaning the hydro clutch could work in the cable trannies but the cable clutches can't work in the hydro? my friend has an exedy stage 1 in good condition in his ef cable tranny.i'm gonna be running the same motor but with hydro tranny in my eg. need a solid answer
Re: question about clutch and flywheel between cable and hydro tranny (EFB16ACRX)
the flywheel work for sure
the clutch on the other hand will not..the 90-91 Integra LS,RS, etc. and the cable b16 trannies have a diffrent input shaft....BUT the 92-93 cable b series trannies have the same input shaft as the 94+ hydros..
But to answer your question...No the clutch will not work but yes the flywheel will work..
Sorry if this confused anyone...
Brandon
Brandon
SiBuddy00
06-21-2005 07:57 PM
TurboBumblBee
12-02-2003 09:09 PM
