clutch and flywheel question??
Old Dec 1, 2003 | 07:15 PM
TurboBumblBee's Avatar
Default clutch and flywheel question??
a friend is going to give me his clutch, flywheel and presure plate out of his first gen b16 cause he is selling the motor... my question is
Will a clutch, flywheel, and presure plate from a b16 (first gen) motor and tranny work in my 98 b18c1 swap??
im thinking they will work cause its still a b series motor and i know you can use put a b18c1 motor into a 91 hatch using an cable transmission.. thanks
Old Dec 1, 2003 | 09:17 PM
Fobtions's Avatar
Default Re: clutch and flywheel question?? (Hybrid95CivicEX)
everything will work except for the clutch disc.
Old Dec 1, 2003 | 09:36 PM
turbo*s2k's Avatar
Default Re: clutch and flywheel question?? (Fobtions)
how come it won't work? I thought they were all the same.
Old Dec 2, 2003 | 12:43 AM
Fobtions's Avatar
Default Re: clutch and flywheel question?? (TurboChrgd_Civic)
the cable tranny uses a smaller sized spline. unless the cable tranny your friend was using was a 92-93 cable tranny,
Old Dec 2, 2003 | 05:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">the cable tranny uses a smaller sized spline. unless the cable tranny your friend was using was a 92-93 cable tranny,</TD></TR></TABLE>
i think it is cause he said it was from an LS integra i think
Old Dec 2, 2003 | 08:18 AM
turbo*s2k's Avatar
your right. I didn't catch that.
Old Dec 2, 2003 | 09:45 AM
is there a way i can measure or find out the part numbers? i dont want to take off his tranny and then go to install it in my b18c1 and find that it doesnt work!
Old Dec 2, 2003 | 09:49 AM
Fobtions's Avatar
i know for sure that the disc wont work casue it is off of your friends b16a with cable tranny. just use your old disc if its still ok.
Old Dec 2, 2003 | 09:50 AM
Kendall's Avatar
Or use the opportunity to go aftermarket with some of the components.
Old Dec 2, 2003 | 10:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">i know for sure that the disc wont work casue it is off of your friends b16a with cable tranny. just use your old disc if its still ok.</TD></TR></TABLE>
use my disc? thats whole reason im getting his aftermarket clutch and flywheel cause mine needs to be replaced!
Old Dec 2, 2003 | 10:57 AM
Fobtions's Avatar
u are going to need a new disc then anyways. and still no, his wont work.
Old Dec 2, 2003 | 01:52 PM
mattssi's Avatar
I used my stage III clutct setup off my first gen b16 with 92 ls tranny? Works fine! The early 90-91 integras had tranny's that have smaller spindals, but the 92-93+ one's have the current size?
crxpwr1
Sep 11, 2006 07:27 PM
blk007
Jul 13, 2005 04:21 AM
tegsp
May 20, 2005 08:06 PM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
TurboBumblBee
Dec 2, 2003 09:09 PM
