brake help
Old Dec 1, 2003 | 04:22 PM
99SlammedCivic's Avatar
Snipper Snapper
Default brake help
Hey guys, I got my AEM Big Brake kit put on about a month and a half ago.
The past week, my steering wheel has been shaking real bad when I brake.
I had a shop install these for me. Is it their fault or what is it?
PLEASE HELP ASAP!
Thanks
Old Dec 1, 2003 | 04:26 PM
Kendall's Avatar
It's possible that they have become misaligned. I don't know if the AEM brakes are prone to warping or not but that could also be the problem.
Old Dec 1, 2003 | 06:35 PM
Snipper Snapper
not to sound stupied, but what does warping mean?
Old Dec 1, 2003 | 06:42 PM
Mohudsolo's Avatar
Default Re: (IceCivic18s)
The braking surface of the rotor gets shaped like a potato chip. When you brake the caliper and pads try to follow this shape and wobble back and forth. Unless you have been racing the car, I would find it hard to believe they are warped. They may just have a buildup of pad material that transferred unevenly. You could try having the rotors turned to see if that cures it. If it is warping, turning could take enough material off the rotors that they will warp again even easier. Being as the rotors are so new, I would suggest discussing it with AEM and see what they have to say. Myabe they had a bad batch or have seen the problem before and can suggest a solution.
Old Dec 1, 2003 | 06:44 PM
Turbo12acer's Avatar
means that teh disks are not strait. like havign the disk bent a bit. instead of this || its more like this //. if its bad enought you can basically see the disks wobbling
Old Dec 1, 2003 | 07:45 PM
vtekstorm's Avatar
Default Re: (Turbo12acer)
when u got yoru brake upgrade done how fast were u driving when u first got them installed. reason y im asking is cuz there is a what u call a break in period for the brake. when eva u get new brakes or a new set up you shouldnt take the car up to exxcessive speeds like no more that 65mphs. because the bakes have to break in properly and seat correctly good luck man
Old Dec 2, 2003 | 06:24 PM
Snipper Snapper
Default Re: (vtekstorm)
Hey guys, thanks for the replies.
I took the car to a Brake shop and they said it was probably "warping".... or maybe alignment
Then I took it to two more shops and the guys said that they were not sure about aftermarket brakes and did not want to be liable if they messed them up.
I think I WILL CONTACT AEM and SEE whats up... Thanks guys
I'll keep u guys updated on what it is...
Later
jaydm73
Feb 19, 2008 02:54 PM
Andy099
Sep 26, 2005 05:26 PM
tlclee
Sep 20, 2003 10:03 AM
kahlua2323
Jun 8, 2003 02:47 PM
mglude
Jan 21, 2003 06:53 AM
