Anaerobic-type sealant......
Old Dec 1, 2003 | 02:42 PM
_jester_'s Avatar
Default Anaerobic-type sealant......
Putting my cams back in....calls for this. I searched and found 1 thread....Is it true you can use RTV for the bearing caps? I don't want to use the wrong goo and fucup
Old Dec 1, 2003 | 02:43 PM
b18bturbo's Avatar
Default Re: Anaerobic-type sealant...... (XratedSi)
you jsut need assembly lube for the bearing caps dont use RTV you will **** up biig time. Any good assembly lube should do the trick.
Old Dec 1, 2003 | 02:50 PM
_jester_'s Avatar
Default Re: Anaerobic-type sealant...... (b18bturbo)
I understand what to use for the lobes and journals- The manual says "Apply anerobic-type sealant to the cylinder head contact surfaces of bearing caps 1 and 5 and install"
So don't use oem gray at these points?
Old Dec 1, 2003 | 03:04 PM
b18bturbo's Avatar
yes that is correct they are where the seals go they keep them in place use hondabond style sealent
B18EG6
Nov 5, 2005 06:27 PM
914doorls
Jun 7, 2005 09:44 PM
unknown0001
May 29, 2005 08:54 AM
