How to change from 3 wire to 2 wire IACV?
Old Dec 1, 2003 | 12:54 PM
Pfieff's Avatar
Default How to change from 3 wire to 2 wire IACV?
My current setup is a y7 running a p06 ecu chipped with hondata. The idle has sucked and I have been unable to come up with the culprit. I am currently running a 3 wire IACV that was on my y7 TB and I was told this is what is causing the shitty idle becuase the p06 only recognizes 2 wire IACV. Is there any post or thread or if anyone could help me out, or let me know if this is def. the problem. Thanks,
Pfieff
Old Dec 1, 2003 | 12:57 PM
Spade's Avatar
Default Re: How to change from 3 wire to 2 wire IACV? (Pfieffdog)
put a block off plate between the IACV and the TB and see if it is the IACV.
Old Dec 1, 2003 | 01:09 PM
Pfieff's Avatar
How would one go about doing a block off plate. If i disconnect the IACV what happens with the coolant running through the lines? I am just a little confused if you could help me out I appreciate it. Thanks,
Old Dec 1, 2003 | 07:18 PM
Pfieff's Avatar
ttt
Old Dec 2, 2003 | 09:47 AM
Del_Sol_s's Avatar
i sort of had a similar problem. i have a 92 vx and dropped in a automatic d16y8. that one came with the 3 wire iacv. what i had to do is buy the intake manifold and throttle from a manual and now it works fine. i know u are running a y7 and i dont know how to convert itthe 3 wire to 2 wire. i thought i could do that too. my suggestion would be to get a y8 intake manifold and throttle body from a manual engine, they come with 2 wire iacv. but thats just me.
xKING239x
Mar 29, 2013 10:03 AM
youryanyou
Feb 9, 2011 12:43 AM
boricuacivic
Apr 6, 2009 09:02 AM
