just finished gsr swap need help
Old Dec 1, 2003 | 12:12 PM
rkn527's Avatar
Default just finished gsr swap need help
i put a 95 gsr swap in my 93 coupe everything is fine but i have ran into problems at the end the throttle cable i have is a ls throttle cable i need to know how does the gsr throttle cable work and how is it ran i had a b18b in there before so i had to buy the ls cable does anyone know if i need to wire a knock sensor or anything else!
Old Dec 1, 2003 | 12:27 PM
jeremyEG's Avatar
Default Re: just finished gsr swap need help (rkn527)
what model is your coupe? if its anything but an ex you have to run the vtec wires and the knock sensor and the IAB for the intake manifold.
for the throttle cable, just try the one that you already have in there. or the stock civic one. i used the stock cable for my gsr swap.
Old Dec 1, 2003 | 12:43 PM
rkn527's Avatar
Default Re: just finished gsr swap need help (jeremyEG)
it is a ex coupe
Old Dec 1, 2003 | 12:56 PM
jeremyEG's Avatar
you will only need to run the knock sensor, and IAB.
Old Dec 1, 2003 | 01:17 PM
salbaje's Avatar
if you are running stock gsr obd1 ecu you will need to run knock,vtec wires (unless you got ex). if running chipped p28 no need for knock
Old Dec 1, 2003 | 01:28 PM
rkn527's Avatar
Default Re: just finished gsr swap need help (salbaje)
THANKS HT
import-tooner
Jan 25, 2011 05:30 AM
90efsedan
Nov 22, 2009 08:03 AM
DAmnquickDA
Jul 23, 2007 06:14 PM
Civichx1998
Nov 27, 2006 03:58 PM
rkn527
Nov 30, 2003 06:58 PM
