just finished gsr swap need help
i put a 95 gsr swap in my 93 coupe everything is fine but i have ran into problems at the end the throttle cable i have is a ls throttle cable i need to know how does the gsr throttle cable work and how is it ran i had a b18b in there before so i had to buy the ls cable does anyone know if i need to wire a knock sensor or anything else!
Re: just finished gsr swap need help (rkn527)
what model is your coupe? if its anything but an ex you have to run the vtec wires and the knock sensor and the IAB for the intake manifold.
for the throttle cable, just try the one that you already have in there. or the stock civic one. i used the stock cable for my gsr swap.
if you are running stock gsr obd1 ecu you will need to run knock,vtec wires (unless you got ex). if running chipped p28 no need for knock
import-tooner
01-25-2011 05:30 AM
90efsedan
11-22-2009 08:03 AM
